Hi,Jorgie
1. I set the thickness is the 0.4mm with no top layer
2. When I import the gcode from Cura,it shows 60K lines(Vase mode won't show layers but show lines)
3.If you don't want to upload the gcode or any pic.
Then we can't refer to it and we can't give you more help.
Kindly
GeeeTech Color Mixing Software does not change the G Code
Re: GeeeTech Color Mixing Software does not change the G Code
Ok, here is the output G code.
- vase_colored1.zip
- (546.04 KiB) Downloaded 643 times
Thanks!I will check it when I get up.
Hi William,
What did you find?
What did you find?
Today I have the time for a test.
Will let you know later.
Hi William,
Do you have an update? While not an urgent issue, it would be nice to have an answer as to why it worked for you but not me.
Sean
Sean
I've fixed it.
I tried to replaced the "G0 Z0.15" to "G1 Z0.15 F400" then it worked.
You can refer to it:
I've fixed it.
Hi William,
So you have analysed the G code and fixed it. BUT that means the GeeeTech Color Mixing Software is faulty. Correct? LOL
Completely correct!
It is a bug of the color-mixer.
I will talk it with the author.
Thx for your feedback!
I have same problem with Color Mixer 1.1
I slice the STL with Cura 4.3
Please find GCODE in attachment
This is the orignal model : https://www.thingiverse.com/thing:2431575/files (slime)
I try others STL, sometimes it works, sometime not
- G_Fire_Slime.zip
- (600.2 KiB) Downloaded 580 times
