GeeeTech Color Mixing Software does not change the G Code
Jorgie
Post by Jorgie » Sat Mar 02, 2019 9:34 am
I've downloaded, and installed, the windows version of the GeeeTech Color Mixing Software.
Imported a g code file generated by Slic3r.
Coloured the print and then exported the G code.
The input file and output file are identical.
So my conclusion is the software does not work.
Any suggestions?
Re: GeeeTech Color Mixing Software does not change the G Code
Post by William » Sat Mar 02, 2019 10:12 am
I think you should attach the gcode file at first.
Then we can help to check it.
cheers
Jorgie
Post by Jorgie » Sat Mar 02, 2019 10:21 am
Really no point in attaching the G-Code. You can use any G-Code produced by Slic3r to check to see if the software modifies the G-code.
I did try and up load the files, even though they are the same, but the site will not allow the files to be added. Invalid file extention.
Post by William » Sat Mar 02, 2019 10:37 am
You can upload the gcode to Google drive then attach the link or upload the zip type files.
You can check the gcode have the "T0/T1" or not
It means the extruder Switch.
Jorgie
Post by Jorgie » Sat Mar 02, 2019 11:07 am
Just been told on another forum that the colour mixer software does not work in vase mode!
Post by William » Sat Mar 02, 2019 1:44 pm
I think should bet with you.Lol
It seems work with vase mode
vase mode with color mixer.jpg (209.49 KiB) Viewed 22689 times
A10M_rocket vase-1.zip
(1.06 MiB) Downloaded 714 times
Jorgie
Post by Jorgie » Sun Mar 03, 2019 5:23 am
That's great William, the software works for you. Your vase walls seem to be quite thick, so perhaps the software works when the wall thickness is over a certain value.
The G-Code being imported compared to the G-Code that is being exported is the same. So you can look all you like but you won't be able to help me.
The forum does not allow me to directly upload a file, instead I have to use a work around, I see that you are a site admin, so perhaps you could fix that also.
Post by _kaktus_ » Sun Mar 03, 2019 2:20 pm
Hello.
We attach compressed files to posts.
You can easily compress your file to ZIP format, and then you will attach it successfully.
We can then be sure that the attachment is not damaged during upload.
This rule does not apply to image files.
Post by William » Mon Mar 04, 2019 2:21 pm
Hi,guys!
Kaktus is correct.You can refer to it then upload the zip type file
Jorgie
Post by Jorgie » Wed Mar 06, 2019 6:27 pm
So, William, are you still asking me to upload my G code files?
If so, can you please explain your logic? Because I am lost as to why you do not accept that the input file is the same as the output file.
I am asking for help and an Admin quite happily says the software work for him, but does not offer help to understand why it works for him but not me.
Is it the wall thickness? Is it something else?
