Slic3r Settings for Prusa i3 Pro W
JustinSB
Post by JustinSB » Tue Dec 19, 2017 5:36 am
Which ini file should I use for the Slic3r Settings for my Prusa i3 Pro W please?
Re: Slic3r Settings for Prusa i3 Pro W
Post by William » Thu Dec 21, 2017 5:46 pm
Maybe you can refer to it
ProWconfig.zip
(1.34 KiB) Downloaded 2105 times
JustinSB
Post by JustinSB » Thu Dec 21, 2017 7:14 pm
Thanks William, I'm trying it right now...
JustinSB
Post by JustinSB » Thu Dec 21, 2017 11:55 pm
William, this has the Nozzle Diameter set to 0.4mm, but I'm now pretty sure that the current batch of Pro W printers are shipped with a 0.3mm Nozzle?
richardradford
Post by richardradford » Wed May 09, 2018 7:27 pm
Hi Justin - Did you use these settings "as is" or did you end up modifying them?
JustinSB
Post by JustinSB » Thu May 17, 2018 4:55 am
After I fixed the nozzle size so that it actually matched what was on the Pro W that I had, I think that they were pretty much "as is".
mitch76
Post by mitch76 » Tue Aug 14, 2018 12:37 am
hi, i try this config with horrible result... anything new?
