Hi guys, I am trying to install a 3D Touch on my Geeetech a10, but don’t understand the circuit board. Does anyone know where I should be plugging the 3 pin and 2 pin plugs into?
All the pics I can find online are of the new main board (which has a dedicated area for the 3D Touch) and not the one I have.
Also, there is a plug called “PWM BLO”, does anyone know what this is?
Thanks!
3D Touch on Geeetech A10?
- Contact:
Re: 3D Touch on Geeetech A10?
This is the best 3D printer which can help us to make a project of our work and as maintained by Book Publishing their finishing is great for the projects.
One can also look out for the top ruby on rails development companies to get their gaming apps done.
Tap 3D & Haptic Touch. Depending on the device you have, only the 3D Touch or the Haptic Touch option might appear. For 3D Touch, turn on the feature, then use the slider to select a sensitivity level. PMP Payslip Portal
