Hi,Guys
something about the PRO B z-axis step value
Since the z-axis screw may be different,
The step value in the firmware is 400 by default.
You can modify and save it on the screen according to the situation.
About the z-axis step value
Re: About the z-axis step value
Hey, how can I change my z axis step value in the firmware using the Arduino IDE?
I actually have the opposite problem, where I need to change it from 2560 to 400.
Thanks,
-Tony
Thanks,
-Tony
orbis heater scam
orbis heater scam
Last edited by farolosourgeois on Sat Nov 20, 2021 1:40 pm, edited 1 time in total.
If you need the source code, please check the link: https://github.com/Geeetech3D/Prusa_I3_3Dprinter
Love this game so much! Let's share it with many people, because it is a great game. Too awesome spades
The z-axis step value is the distance from the origin or origin in a direction parallel to the z-axis.
The default value for this axis is 0.
If you specify a value for this axis, then this axis will be used for all coordinates in that coordinate system.omegle bazoocam chatrandom
Hello, how might I change my z pivot step esteem in the firmware utilizing the Arduino IDE?
I really have the contrary issue, where I really want to transform it from 2560 to 400.
Much appreciated,https://www.omegle.fyi/ https://www.bazoocam.fyi/ https://www.chatrandom.one/
