3D printer manual mode level guide
Admin
Post by Admin » Fri Jan 25, 2019 2:28 pm
3D printer manual mode level giude.
Guide For A10/A10M/A20/A20M 3d printer
Here are the steps:
1.Power off the printer PSU
2. Move the hotend to X0 point(If you don't do it, the nozzle may hit the heat bed)
Move to X0.png (1.42 MiB) Viewed 29948 times
3. Click the LCD bottom then select"Prepare">"Auto home"
4.1) Then you need to disable the stepper motor.
2)LCD>"Prepare">"Disable steppers"
5. Tight the print platform adjustable screws at max
6. You need to move the hotend and find the lowest point of the print platform(5 Points)
7.1)You need to prepare an A4 paper
2)Move the hotend to the lowest point,
Put an A4 paper between the nozzle and the print platform
Adjust the adjustable screw until the nozzle hit the A4 paper
When you pull A4 paper, if your hand feels a little of resistance and the paper hard to move. It means this point level finished.
Refer to the picture below to check if the leveling is correct.
8.Refer to the step of NO.7 level other 4 points
9. When you have completed the first leveling, you still need to confirm again.
Leveling can be completed in about 2~3 times.
10.If it is hard to level the print platform.
You can remove the print platform off and put it on the desk.
Then you can check it bent or not.
If it bent,pls contact the sales and ask them to get more help.
FredR
Re: 3D printer manual mode level guide
Post by FredR » Sun Feb 03, 2019 2:00 am
This worked perfectly the first time. Making sure you repeat the process 3 or 4 times like you said. Every time will fine tune it each round. At the end, it came together perfectly and my first demo print came out perfect! Thanks for showing us!
fucyc
Post by fucyc » Tue Oct 27, 2020 1:23 pm
The board of the index that has fields to get data with the fiction to create guides among the parts to have the quick links. The level guide has a manual to print can be share by assignment writing service this was the company that works in this city for long work with the parties to get data about the prediction.
followersaustralia2
Post by followersaustralia2 » Wed Nov 25, 2020 11:46 pm
6 Simple Steps to 3D Printer Bed Leveling · 04 21 , 2016 7 ... Photo source: Simplify3D Troubleshooting Guide. 2. Gaps in your initial layer or by Epicfollowersuk
followersaustralia2
Post by followersaustralia2 » Wed Nov 25, 2020 11:47 pm
Learn how to use your 3D printer's auto-leveling probe for a perfect first layer! ... Beginner's Guide to Auto Bed Leveling in Simplify3D ... After the profile has loaded, click “Edit Process Settings”, go to the Scripts tab, and select the Starting script. ... please refer to our extensive troubleshooting guide for more info on this topic.
buy instagram followers cheap
FredJD
Post by FredJD » Thu Mar 04, 2021 11:58 pm
Thanks for the Manual Guide steps and clean explanation, I got lot of infomation from here. I have GeeeTech 3D Printer and It's working nicely, Great brand with full of works.
zakota92
Post by zakota92 » Thu Jul 15, 2021 8:00 am
It was very amazing game project qt mod apk love the story and characters love the ending it was funny too hope you guys make more of these games you guys are the BEST
javed5711
Post by javed5711 » Sat Sep 04, 2021 3:35 pm
Download Tekken 3 APK as it is the best android game...
buyfollowersaustralia
Buy Instagram Followers UK
Post by buyfollowersaustralia » Sun Oct 17, 2021 1:31 am
Geeetech has been one of the most prominent rising star in the area of 3D printing in Shenzhen ,China, even the world, since founded in 2011.Geeetech advocates ... by Buy Instagram Followers UK
Buy Instagram Followers Australia
Post by buyfollowersaustralia » Sun Oct 17, 2021 1:32 am
Geeetech is a Chinese open source electronics manufacturer specialising in open source 3D printers. They are one of the largest 3D printer companies in ...
by Buy Instagram Followers Australia
