Problems with Extruder - 1
Jukalokaduka
Post by Jukalokaduka » Sat Aug 22, 2020 3:17 pm
If I input an extrusion of 10mm extruder 0 will extrude exactly that, 10mm. However, if I input an extrusion of 10mm it will extrude about 100 mm. I don't know what setting will change the extruder settings for just the second extruder, any advice? I am using the dvr8255 motor drivers as well.
Re: Problems with Extruder - 1
Post by William » Mon Aug 24, 2020 10:24 am
Hello, you can check the step value of extruder 1, it may be too large, you can also check whether the spring of extruder 1 is loose, resulting in too fast feeding. :D
