Z axis problem
novawaves
Z axis problem
Post by novawaves » Sat Mar 21, 2020 4:33 pm
Hi geekd
I need help
My problem is that the z axis turns but i think it turns bot enough therefore the printed object is flat and only 4 layer high
I look to the steper motors and they turn after layer change but i think they turn to little. I changed the step motor controllers between z and x axis without success.
I used cura for the first time and the fine with 0.1mm also i try some gcodes but i dont know now which one. Before that everything was ok
I tried also a firmware reflash without success.
I think it is no mechanical problem only a software variable one.
Please help me what i can try and how to reset everything to factory defaults.
Thx
Re: Z axis problem
Post by William » Sat Mar 21, 2020 4:40 pm
Hi,can you provide relevant videos?
can the z-axis motor run normally?
novawaves
Re: Z axis problem
Post by novawaves » Sat Mar 21, 2020 4:54 pm
Yes the z motor turn when u use the manual controll from easyprint 3d and it moves up regulary
My guess is that the z axis moves not enough because manualy it dont hang at a specially position
In cura i have select the prusa i3
The test objects inprinted are flat and 4 layers high
I calibrate the distance from the left and right motor so it is right horizontal
Re: Z axis problem
Post by William » Sat Mar 21, 2020 5:13 pm
Hi, can you control the z-axis movement through the screen?
Such as increasing the z-axis by 10,
If moving to a certain location is difficult,
You can check if the z-axis threaded rod is bent,
Is the coupling installed correctly?
Whether the left and right z axes are on the same horizontal line.
novawaves
Re: Z axis problem
Post by novawaves » Sat Mar 21, 2020 7:36 pm
I used a slide gauge to check it is horizontal ok
Yes i can manuelly move x steps
And the z axis move up right
The rod is a little bend when it turns i can see but this was also so before and the printer works right.
Should i disassembly everything to rebuild?
Can i define the z axis step high much more so that the movement z is right
novawaves
Re: Z axis problem
Post by novawaves » Sun Mar 22, 2020 12:48 am
Is it normly that the z motor runs slower than x and y
I changed the controller y z and y works normaly
Re: Z axis problem
Post by William » Mon Mar 23, 2020 10:31 am
Hi,Can you provide a video of your z-axis motor operation and problems?
novawaves
Re: Z axis problem
Post by novawaves » Mon Mar 30, 2020 3:35 am
Here are some videos of the printing process
https://youtu.be/0yoXt4Cv1A0
https://youtu.be/LOD73AqoHKY
https://youtu.be/PGFQfJBMh2M
I think the printer moves the z axis not enough so there is a factory variable changed or so?
Please help!
Re: Z axis problem
Post by William » Mon Mar 30, 2020 10:35 am
Hi, look print normal.
and about print speed you can refer :30-60mm/s.
novawaves
Re: Z axis problem
Post by novawaves » Mon Mar 30, 2020 10:24 pm
hi
yes it prints normal the first layers but when the object is higher than 1mm the extruder squish the object so i think the movement of the z axis is not right.
befor that problem everysthing was right but than i have used some G-Codes but i dont know which one.
therefore i have tought i reflash the firmware but without success. the printer dont print normaly! look at my printed object there you see the problem
i move the z axis manually and there is no resistance on the z axis and the movement is normal over the stepper motors
