Z axis problem
Re: Z axis problem
Post by William » Tue Mar 31, 2020 10:28 am
Hi, can you use screen to move the zaxis?
such as 10 or more?
and change the model to slicr.
novawaves
Re: Z axis problem
Post by novawaves » Tue Mar 31, 2020 5:56 pm
hi,
now i have a new info. yesterday i notice that the 4 screw on the left threaded rod is loose. so i tighten the screws and the rod will move much harder, when i loosen it the rod will move light. than i saw that the rod is a litte bit bent. do you think this could be my problem? where did i get a new rod?
thx
Re: Z axis problem
Post by William » Tue Mar 31, 2020 6:10 pm
Hi, are the four screws on the brass screws,
Does it play a fixed role?
You can see if the threaded rod is bent,
If you bend, you can contact your sales description.
novawaves
Re: Z axis problem
Post by novawaves » Wed Apr 01, 2020 3:57 am
hi could you please give me the standard definition which i have to input in control motion menu
please tell me all the constants which are standard in these menu
thx
novawaves
Re: Z axis problem
Post by novawaves » Wed Apr 01, 2020 4:14 am
now i have make a big progress
i have changed the steps / mm for the z axis to 2600 and the extruder moves approximately 10mm when i use the manual controll
so i think i have changed the steps/mm for my i3x with a gcode that i have used.
when i reflash the firmware the steps/mm are 400 so there is a big difference
why is this so and what are the correct factory defaults?
please give me all the factory constants
thx
Re: Z axis problem
Post by William » Wed Apr 01, 2020 9:40 am
Hi, you can refer to this: viewtopic.php?f=66&t=69776
novawaves
Re: Z axis problem
Post by novawaves » Wed Apr 01, 2020 1:43 pm
thank you thats the solution, the firmware i updated have 400 steps/mm and i have the left rod wich neets more steps!
Re: Z axis problem
Post by William » Wed Apr 01, 2020 1:44 pm
:D
topcar
Re: Z axis problem
Post by topcar » Tue Apr 12, 2022 6:04 pm
The 2022 Jeep Grand Cherokee hpr comes standard with a 6.4-liter V8 SRT engine that develops 475 horsepower and 470 pounds. from the torque. https://www.gtopcars.com/makers/jeep/20 ... -cherokee/
imtopautomag
Re: Z axis problem
Post by imtopautomag » Sat May 21, 2022 7:03 pm
The best and top rating SUVs, auto magazines, coupes, Scooters, Motorcycles, wagons, convertibles, minivans, hybrids, and future bikes model collection with photos.https://www.instapaper.com/p/topautomag
