Faulty power plug
tbs_dk
Faulty power plug
Post by tbs_dk » Thu Jun 11, 2020 11:47 pm
Had an issue where i got home to failed print and after i removed everything and wanted to start over i found that the bed would not heat up.
Then i had a closer look at the board and found that the PSU plug was all burned on one of the 12volt rails.
now i have to locate new plugs and solder a new one on to the board and hope nothing is fried.
But i cannot understand why / how this could have happend as the plug on the board and the cord are something what i made form the factory and not something you have to assemble your self.
And also just happy that it did not end i something worse like a fire..
Re: Faulty power plug
Post by William » Fri Jun 12, 2020 10:19 am
Hello, sorry for this situation, you can contact the salesperson to replace the line and motherboard.
tbs_dk
Post by tbs_dk » Fri Jun 12, 2020 11:07 pm
HI
Thanks i will try. But as i bought this printer from a 3rd party and not directly from Geeetech i am not sure that Geeetech would replace the board.
And its not just the board its also the cable from the PSU that have the male end of the plug.
Post by William » Mon Jun 15, 2020 9:21 am
Hello, you can consult customer service on the purchase platform.
Under normal circumstances, the seller will also deal with after-sales.
