Error sending command
Rush68
Post by Rush68 » Thu Oct 17, 2019 3:46 am
This happens to me when I send to print.
after three or four attempts already prints, I upload video, sorry, How can I upload a video?
Re: Error sending command
Post by William » Thu Oct 17, 2019 9:25 am
:D Hi. you can provide the link address of your uploaded video.
So that we can solve the problem better.
Rush68
Post by Rush68 » Thu Oct 24, 2019 6:33 am
https://we.tl/t-iv9KfXsJHu
here is the link for the video,
this happens when i sent to print,
after several attempts print
Post by William » Thu Oct 24, 2019 9:13 am
Hi,You can check the status of the limit switch,
connect to the printer via usb and enter M119 in the manual control of the Repetier Host.
You can refer to this: http://www.geeetech.com/forum/viewtopic ... 13&t=17042
Rush68
Post by Rush68 » Fri Oct 25, 2019 3:01 am
In my case, everything is fine, I send home and everything is fine.
The same with the scripts.
the problem is that I send to print and everything is fine sometimes, but I often send to print and instead of going down after doing at home, it goes up
Sorry my english is very bad
Rush68
Post by Rush68 » Sun Oct 27, 2019 4:48 am
When send to print and instead of going home and then lowering goes to the coordinate in z 204.71, thats is the crash.
Rush68
Post by Rush68 » Fri Nov 08, 2019 12:43 pm
I solved the problem.
If I send to print from the sd card everything goes very well
thanks for your support
