GTM32 Pro vB controller board - how to read.
Post by _kaktus_ » Mon Jun 25, 2018 10:22 pm
:mrgreen:
For everyone who wants to know details, I have prepared a description of the GTM32 Pro vB controller board. :mrgreen:
The description contains many details useful for the DIY construction.
My printer model, M201, has this controller board.
Delta Rostock 301 uses the same controller. :D
However, it has different software so some details may differ slightly in operation.
If you are interested in this topic read it: kaktus' guide - GTM32 Pro vB controller board - how to read.
I wish everyone a nice day. ;)
Tio
Re: GTM32 Pro vB controller board - how to read.
Post by Tio » Thu Aug 16, 2018 1:23 am
hi, very usefull for detect a problem in my board. thanks
roshni
Post by roshni » Thu Jul 30, 2020 1:12 am
A Python developer has to use fewer lines of codes to write apps. Both big and small companies are using Python to develop software as it has multiple paradigms of programming. Therefore, Python developer as a career option has become quite lucrative.keep continue with us.it will help u lot guys..thanks a lot guys..
https://www.acte.in/python-training-in-chennai
https://www.acte.in/python-training-in-bangalore
https://www.acte.in/pyhon-training-in-hyderabad
https://www.acte.in/python-trainting-in-coimbatore
https://www.acte.in/python-online-training
Maxwelll
Post by Maxwelll » Wed Sep 09, 2020 5:05 pm
1. Введение
GTM32 является полностью саморазработанной, с открытым исходным кодом, управляемой Geeetech для высокопроизводительных 3D принтеров. Он поддерживает однородно оптимизированные Спецификации интерфейса Geeetech, легко собирается и с компактной раскладкой, высокой интеграцией и высокой производительностью.
GTM32 плата управления (далее именуемая как плата управления) принимает Текущий основной высокопроизводительный Cortex M3 core chip STM32F103 с частотой работы до 72 МГц. плата управления поддерживает до 4 шаговых двигателей, а именно, осевой двигатель XYZ и экструдер. Пользователи могут заменить модули вождения, такие как A4988 и TMC2100 модули, в соответствии с их собственными потребностями. Кроме того, он использует высокопроизводительный USB Серийный чип FT232RL, который позволяет пользователям управлять контрольной платой через USB кабель. Gacha life Выходное напряжение составляет 12 В.
ЖК-дисплей 2004-это основной 20 символов 4-линейным матричным модулем контроллера, предназначенным для различных материнских плат 3D принтеров. Продукт содержит 20 символов x 4 линейный ЖК-дисплей, поворотный кодер и соединительные кабели 30 см. На задней части ЖК-модуля есть слот для sd-карты, соединяющий его с платой контроллера 3D принтера. Просто вставьте sd-карту в sd-слот, вы можете печатать 3d-модели без ПК.
fara12
Post by fara12 » Fri Mar 25, 2022 3:42 pm
Parallels Desktop Crack is really one of the genuinely most helpful VM software software. It tackles Mac OS X pc with extremely cheap specs. It is always a protected system which permits the drivers to create the digital gadget quickly, and it can help or not it's easy to jog Windows OS on the Mac laptop computer system. https://freeprosoftz.com/parallels-desk ... -free-key/
