I guess the users of this printer model have not received such manual and maybe they will be happy now.
Here are the results of my work:
Menu-tree for the DELTA Rostock 301 printer, with firmware version 1.0.04, per day 2018-05-25
1. Info screen.
Info screen
1. Prepare
2. Control
3. Mixer
4. SD Card
1.1 Prepare.
Main
Disable Steppers
Auto Home
Preheat PLA
Precheat ABS
Cooldown
1. Move Axis
1.1.1 Move Axis.
Prepare
1. Move 10mm
2. Move 1mm
3. Move 0,1mm
1.1.1.1. Move 10mm.
Move Axis
1. Move X
2. Move Y
3. Move Z
1.1.1.1.1. Move X.
X: 0.0
1.1.1.1.2. Move Y.
Y: 0.0
1.1.1.1.3. Move Z.
Z: 0.0
1.1.1.2. Move 1mm.
Move Axis
1. Move X
2. Move Y
3. Move Z
4. Extruder 0
5. Extruder 1
6. Extruder 2
1.1.1.2.1. Move X.
X: 0.0
1.1.1.2.2. Move Y.
Y: 0.0
1.1.1.2.3. Move Z.
Z: 0.0
1.1.1.2.4. Extruder 0.
Extruder 0: 0.0
1.1.1.2.5. Extruder 1.
Extruder 1: 0.0
1.1.1.2.6. Extruder 1.
Extruder 2: 0.0
1.1.1.3. Move 0,1mm.
Move Axis
1. Move X
2. Move Y
3. Move Z
4. Extruder 0
5. Extruder 1
6. Extruder 2
1.1.1.3.1. Move X.
X: 0.0
1.1.1.3.2. Move Y.
Y: 0.0
1.1.1.3.3. Move Z.
Z: 0.0
1.1.1.3.4. Extruder 0.
Extruder 0: 0.0
1.1.1.3.5. Extruder 1.
Extruder 1: 0.0
1.1.1.3.6. Extruder 1.
Extruder 1: 0.0
2. Control.
Main
1. Temperature
2. Printer Settings
3. Delta
4. Motion
Store Memory
Restore Defaults
Version
2.1 Temperature.
Control
Nozzle: 0
Bed: 0
Fan speed: 0
Autotemp: Off
Min: 210
Max: 250
Fact:
1. N-PID
2. B-PID
3. Preheat PLA Conf
4. Preheat ABS Conf
2.1.1 Temperature N-PID.
Temperature
N-PID-P: +0608.05
N-PID-I: +0036.63
N-PID-D: +2709.19
2.1.2 Temperature B-PID.
Temperature
N-PID-P: +0369.61
N-PID-I: +0054.13
N-PID-D: +0602.87
2.1.3 Preheat PLA Conf.
Temperature
Fan speed: 0
Nozzle: 200
Bed: 70
2.1.3 Preheat ABS Conf.
Temperature
Fan speed: 0
Nozzle: 200
Bed: 70
2.2 Printer settings.
Control
X Max: 85
X Min: -85
Y Max: 85
Y Min: -85
Z Max: 229
Z Min: 0
Home X: Max
Home Y: Max
Home Z Max
X Motor Dir: Truee
Y Motor Dir: True
Z Motor Dir: True
E Motor Dir: True
E1 Motor Dir: False
E2 Motor Dir: False
1. XmaxEndstop:
2. XminEndstop:
3. YmaxEndstop:
4. YminEndstop:
5. ZmaxEndstop:
6. ZminEndstop:
2.2.1 X max Endstop.
Printer settings
Logic level: High
Status: NC
2.2.2 X min Endstop.
Printer settings
Logic level: High
Status: NC
2.2.3 Y max Endstop.
Printer settings
Logic level: High
Status: NC
2.2.4 Y min Endstop.
Printer settings
Logic level: High
Status: NC
2.2.5 Z max Endstop.
Printer settings
Logic level: High
Status: NC
2.2.6 Z min Endstop.
Printer settings
Logic level: High
Status: NC
2.3. Delta.
Segments/sec: 200
Diagonal Rod: 196
Smooth offs: 160
Effecter offs: 36
Carriage offs: 33
Delta Radius: 86.0
Print Radius: 90
2.4. Motion.
Control
Z offset: 0.00
Accel: 5000
Vx-jerk: 20
Vy-jerk 20
Vz-jerk: 0
Ve-jerk 5
Vmax X: 400
Vmax Y: 400
Vmax Z: 400
Vmax E: 1000
Vmin: 5
VTrav min: 5
Amax X: 5000
Amax Y: 5000
Amax Z: 5000
Amax E: 800
A-retract: 3000
Xsteps/mm 80.26
Ysteps/mm 80.26
Zsteps/mm 80.26
Esteps/mm 95.00
Home speed X: 360
Home speed Y: 360
Home speed Z: 360
3. Mixer.
Prepare
Filament 0: 100%
Filament 1: 0%
Filament 2: 0%
1. OFP
2. Templates
3. Custom
3.1 OFP.
Mixer
OFP Max: 100%
OFP Min: 0%
Store Memory
3.2 Templates.
Mixer
Template 1
Template 2
Template 3
Template 4
Template 5
Template 6
Template 7
Template 8
Custom 1
Custom 2
Custom 3
Custom 4
Custom 5
Custom 6
3.3 Custom.
Mixer
1. Custom 1 Conf
2. Custom 2 Conf
3. Custom 3 Conf
4. Custom 4 Conf
5. Custom 5 Conf
6. Custom 6 Conf
3.3.1 Custom 1 Conf.
Custom
Start Percent: 0%
End Percent: 100%
Start Height: 0.0
End Height: 100.0
Store Memory
3.3.2 Custom 2 Conf.
Custom
Start Percent: 0%
End Percent: 100%
Start Height: 0.0
End Height: 100.0
Store Memory
3.3.3 Custom 3 Conf.
Custom
Start Percent: 0%
End Percent: 100%
Start Height: 0.0
End Height: 100.0
Store Memory
3.3.4 Custom 4 Conf.
Custom
Start Percent: 0%
End Percent: 100%
Start Height: 0.0
End Height: 100.0
Store Memory
3.3.5 Custom 5 Conf.
Custom
Start Percent: 0%
End Percent: 100%
Start Height: 0.0
End Height: 100.0
Store Memory
3.3.6 Custom 6 Conf.
Custom
Start Percent: 0%
End Percent: 100%
Start Height: 0.0
End Height: 100.0
Store Memory
4. SD Card.
Main
note: all options do have default values.
With dedication to my colleague Ali Mir and my friend from the Geeetech team.
In addition, a warm greeting to the Geeetech sales staff.
kaktus' guide - Menu-tree Rostock 301, FW v1.0.04
Re: kaktus' guide - Menu-tree Rostock 301, FW v1.0.04
Fine to see the Menu-tree... But where can i download the firmware??
There is a corresponding section in the forum.
There is also information on how to do it.
Please read the forum because it is worth it.
Thanks for the info. I was in the firmware section, but cant find this FW v1.0.04 anywhere. The only way to get it was via easyprint software from Geeetech.
Btw. why in the new FW v1.0.04 suddenly my Rostock 301 extrudes Filament after my printjob end. I have no option to switch that off!
I dont want that.
I dont want that.
I think you could add end Gcode in slicer software to turn off nozzle and bed heating:MarcusMGT wrote: ↑Mon Jun 11, 2018 1:35 amThanks for the info. I was in the firmware section, but cant find this FW v1.0.04 anywhere. The only way to get it was via easyprint software from Geeetech.
I dont want that.
M104 S0 ; turn off nozzle temperature
M140 S0 ; turn off bed temperature
When colling down, filament can stop coming out.
- M104 S0.jpg (28.65 KiB) Viewed 38706 times
I have some advice for you.
Search in your slicer for an option to edit "end code".
Add a filament retraction command for each feeder (extruder).
This will reduce the pressure in the head (hot end) and the melted plastic should not flow out of the nozzle.
Info screen.
Basically, it's the main screen. Its content is visible immediately after switching on the printer's power supply.
The first line:
- After pressing the encoder button, the level 1 menu is started.
- Rotating the trigger knob directly changes the responsible value of the printer's operating speed. This way you can increase or decrease the print speed.
Changes can be made during the printing process.
The first line:
- contains information about the temperature reached and set for the head (hot end) and the heated work table (heat bed).
On the left side the information for the head on the right side of the work table is displayed.
e.g.
18/0° - means current temperature 18°C, setpoint temperature 0°C.
A zero value for the setpoint temperature means that heating is deactivated.
A zero value for the sensor display indicates that the temperature is not measured. It may be caused by sensor damage or a failure to contact.
exception: this can happen up to a few seconds after the power supply has been switched on.
- contains information about the ratio of mixing of the material (Mx) and about the current position of the Z-axis mechanism (Z-axis coordinate).
On the left is the information about the set mixing factor of the material, on the right is the current Z axis coordinate.
e.g.
Mx 96/2/2 - means that 98% of the material will be taken from the first extruder and 2% from the second extruder and 2% from the third extruder.
None of the values should be set to 0, which may cause the feeder tube to clog in the head.
The setting is designed for mixing colours.
Z0.00 means that the head nozzle is at a height of 0.00mm above the work table.
- contains information about the speed of the printer's operation, the progress of the printout started from the SD card, the time that has elapsed since the power supply to the printer was switched on.
On the left is the information about the currently set speed coefficient of the printer (FR - frame rate?).
The middle of the line contains information about the printing progress from the SD card.
The right part of the line shows the operating time of the printer.
e.g.
FR100% means operation (printing) at standard speed. A value of less than 100 indicates slowdown, a value of more than 100 indicates that the printer will work faster. You can set the value from the range of 15-300,
SD---% means that the functionality of printing from the memory card is not enabled,
000.00 means that the power supply to the printer has just been switched on.
- Information displayed - text.
You can use Gcode to display your own text.important: we have 20 characters available, including spaces, etc.Code: Select all
M117 drukara M201 kaktusa
As a standard, text is displayed when the power supply is switched on: "SD Card Removed!" when the memory card is not loaded.
If you plug in the SD card - before turning on the power, the presented content is as follows: "SD Card OK!".
This indicates that the card has been correctly detected by the printer's controller.
Very helpful guide! Thank you for sharing this.
Sub-grade Preparation Service
Your post is helping me a lot. Its really nice and epic.
Thanks a lot for the useful info on this topic. FMwhatsapp Download You did it so much well. I love to see more about
thank you for sharing useful information...!
Thanks for sharing to info post but I am using to nulls clash Best Latest Android Version Check now.. & Download..
