i tried to update the firmware via EasyPrint on pc following the instructions of a tutorial on youtube by Geeetech.
During the process the update stopped with the message:"Update Failed", now the printer is stuck and i can't use it. From the display i can access to everything but the settings panel, so i can't reset the printer to the factory settings. Is there a way to fix it?
Printer stopped working after update.
Re: Printer stopped working after update.
How is your printer now?
You can to use this method to update the firmware:
viewtopic.php?f=20&t=60676&p=82222#p82222
If the display still unnormal, the files in SD card for LCD might broken, you can repair it follow this:
viewtopic.php?f=64&t=60677
I fixed it temporally by small welding at mycoles login, but I would like to get a new intact cable on mythdhr login.
If you're encountering this problem, the easiest fix is to roll back the latest Windows update. To do this, open Settings > Update & Security > Windows Update > View Update History > Uninstall Updates > Uninstall, or remove the patch manually in Command Prompt. Some Reddit users confirmed that this fixed their problem.
official website
official website
Looking for the same issue. Bumped into your thread. Thanks for creating it. Looking forward for solution. UPSers Login
