I want to use a MOSFET as a switch driven by my microcomputer.
The original circuit usingp-channel MOSFET is on the left side. Honestly, I do not understand the choice of the IRLZ44. The circuit is designed for Arduino, which has 5V logic. Which means that for GPIO=True=5V, MOSFET opens and lets the current into the load.
However I have two problems:
I am using Raspberry Pi, which has 3.3V logic. According to available information 3.3V is not enough to fully open MOSFET.
I want my load to be connected to the ground (I had to do some voltage measurements).
I know enough electronics to assume that using P-channel MOSFET, as shown on the right side, might solve both of my problems at one stroke. For GPIO=False=0V MOSFET will be fully open, while GPIO=True=3.3V puts -1.7V on the MOSFET gate and practically close it down. If that does not suffice, I could also put GPIO into the listening mode and therefore pull the MOSFET gate to 5V.
Could you please tell me if the idea will work? And what IRLZ44-equivalent P-channel MOSFET should I use?
p-channel MOSFET switch
Jump to
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
