Page 2 of 2
Re: Mk8 Extruder - filament jams in the throat.
Posted: Thu Aug 11, 2016 1:57 am
by benedetto.luca
I’ve do some test and my idea that the barrel are not cooled enough was confirmed!
I’ve design a specific update to my customization in order to redirect the MK8 fan air versus the barrel, so versus the cooling zone:
- Mono Extruder In Place B.jpg (410.26 KiB) Viewed 26053 times
With this I finally am able to print “strange” PLA that ask more degrees, with retraction!
You can find on my
http://www.thingiverse.com/thing:1708971 like all other componets of my customization!
Posted: Sun Dec 11, 2016 10:55 am
by Lami René
Bonjour,
You will find the original text translated into English following this original French text.
J'ai acheté le 24 septembre 2016 une imprimante delta Geeetech Rostock 301 (M301) qui a beaucoup de problèmes de conception. Alors cela ne concerne pas nécessairement que vos problèmes.
Mais dans le sujet suivant, vous trouverez peut-être des pistes de solution que vous pourriez appliquer à votre cas :
http://www.geeetech.com/forum/viewtopic ... 27&t=18578
Cordialement,
L'ami René
I bought on September 24, 2016 a Geeetech Rostock 301 delta printer (M301) which has a lot of design problems. So it does not necessarily concern your problems.
But in the following topic, you may find some possible solutions that you could apply to your case:
Cordially,
Friend René
Posted: Thu Jul 20, 2017 6:21 am
by Soadyheid
you can try fitting a weaker spring in the filament pinch mechanism. The one which came with my printer was too strong and caused the motor to stall (click noise) I fitted a weaker one and ordered an aluminium mechanism which allows you to adjust the pinch pressure.
With the aluminium pinch mechanism fitted and adjusted, no more problems, filament feeds perfectly!
Play Bonny!
Soadyheid
