My slicer settings
zhangxueyou
My slicer settings
Post by zhangxueyou » Sat May 09, 2015 10:37 am
I use Geeetech Prusa i3B, with 1.75mm filament and 0.3mm diameter nozzle. Slicer software is Slic3r. Attachment is my slicer settings, I got good print with these settings, you can try.
Actually, anyone who uses different kinds of printer, or the same printer with different filament diameter or nozzle diameter, can also refer to this setting. But you have to change some parameters in slic3r, including "filament diameter", "nozzle diameter", "first layer height"(it is as same as nozzle diameter), "other layers height"(I suggest lower than first layer for 0.05-0.1mm).
slicer settings(1.75-0.3).zip
(637.06 KiB) Downloaded 3042 times
How to access slicer setting and slice:
Open Repetier-Host, click "configuration" under "Slicer" tab:
Save change after you change every group of parameters.
save parameters.png (22 KiB) Viewed 54128 times
Click "slice with slic3r" to generate g-code:
slice with slic3r.png (15.88 KiB) Viewed 54128 times
You can save the g-code in SD card to print off-line:
save gcode.png (21.03 KiB) Viewed 54128 times
zhangxueyou
Re: My slicer settings
Post by zhangxueyou » Tue May 12, 2015 5:24 pm
You can also load the configuration file too.
slicer config.zip
(1.27 KiB) Downloaded 2290 times
Open slic3r in Repetier Host:
import slicer setting 1.png (46.16 KiB) Viewed 54716 times
import slicer setting 2.png (52.58 KiB) Viewed 54716 times
import slicer setting 3.png (87.36 KiB) Viewed 54716 times
ingsergio
Post by ingsergio » Thu May 14, 2015 10:22 am
Greetings.
Look already sent to print out sero no filament 1.75 abs. Will speed stepper motor extruder?
zhangxueyou
Post by zhangxueyou » Thu May 14, 2015 3:28 pm
ingsergio wrote:Greetings.
Sorry, I don't get your point.
ingsergio
Post by ingsergio » Thu May 14, 2015 9:37 pm
Saludos zhangxueyou.
Ya estoy imprimiendo. Lo unico es que sale como remontada la figura. A que velocidad maneja el motor del extrusor?
zhangxueyou
Post by zhangxueyou » Fri May 15, 2015 8:58 am
ingsergio wrote:Saludos zhangxueyou.
La velocidad de extrusión es 95 mm / s. Se ha establecido en el firmware.
Si desea reducir la velocidad de impresión, Puede girar el saber en la pantalla LCD. Como se puede ver en la tercera línea de la pantalla LCD, "FR 100%" is default printing speed.
Traduzco del Inglés al Español en Google traducir, espero obtendrá mi punto.
ingsergio
Post by ingsergio » Sat May 16, 2015 8:26 am
Greetings.
I now have problems with the 0.3mm nozzle. He was making a solid and suddenly stopped distilling abs. (I was stoppered) disassemble the clean at all (nozzle and part where it passes the filament). Start printing again and still covered. I can do?
zhangxueyou
Post by zhangxueyou » Mon May 18, 2015 2:05 pm
Cuál es la temperatura al imprimir? Cuándo parar?
ingsergio
Post by ingsergio » Mon May 18, 2015 9:05 pm
When this printing varies between 240 and 221.
zhangxueyou
Post by zhangxueyou » Tue May 19, 2015 10:35 am
ingsergio wrote:When this printing varies between 240 and 221.
¿Puede imprimir con la tarjeta SD?
