My slicer settings
ingsergio
Re: My slicer settings
Post by ingsergio » Tue May 19, 2015 11:18 am
No he intentedo. Voy a probar.
zhangxueyou
Post by zhangxueyou » Tue May 19, 2015 11:38 am
usted puede imprimir el archivo de prueba en el archivo adjunto.
If the filament is PLA, print with "Test_40x30x10_PLA_1.75_0.3.gcode".
Test.zip
(35.78 KiB) Downloaded 1036 times
ingsergio
Post by ingsergio » Tue May 19, 2015 8:52 pm
Tengo solo abs.
ingsergio
Post by ingsergio » Fri May 22, 2015 11:30 am
Fue mejor. Se imprimio completo. Con pocas fallas. Lo unico es que aveces no sale filamento cuando esta haciendo la capa y tambien aveces se corre el solido y toca cancelar la impresion.
zhangxueyou
Post by zhangxueyou » Fri May 22, 2015 11:45 am
ingsergio wrote:Fue mejor. Se imprimio completo. Con pocas fallas. Lo unico es que aveces no sale filamento cuando esta haciendo la capa y tambien aveces se corre el solido y toca cancelar la impresion.
la temperatura del extrusor debe ser 240.
Jsantos1214
Post by Jsantos1214 » Mon May 25, 2015 4:42 am
i haven't tried these settings yet. but would this help with the bumpy look? so far my prints have been not so great. i would like to print a design but if its going to be bumpy looking its not going to work with my design. how can i go about doing a fine slow print where i wont have bumps on the print?
zhangxueyou
Post by zhangxueyou » Mon May 25, 2015 10:16 am
Jsantos1214 wrote:Hello,
When printing, you can rotate the knob on LCD anticlockwise to lower the speed, you can see the percentage on the thirdline of LCD.
You can also set the speed in slicer setting:
FLeeX
Post by FLeeX » Wed Jun 22, 2016 10:08 pm
zhangxueyou wrote:You can also load the configuration file too.
slicer config.zip
Open slic3r in Repetier Host:
Tell me please why the settings are totally different compared to those files you uploaded here? It's all different between this "Slicer config" and "Slicer settings", I don't understand lol
TommyE
Post by TommyE » Thu Sep 14, 2017 4:47 pm
Thanks for the clarification! I'll try these settings.
Wanna know why I'm playing at casinogamesclubcom? It provides an awesome collection of online slots. The chances have are sky high. Just follow me there.
ronw
Post by ronw » Tue Sep 01, 2020 8:53 pm
zhangxueyou wrote:
Fri May 15, 2015 8:58 am
ingsergio wrote:Saludos zhangxueyou.
Ya estoy imprimiendo. Lo unico es que sale como remontada la figura. A que velocidad maneja el motor del extrusor?
La velocidad de extrusión es 95 mm / s. Se ha establecido en el firmware.
Si desea reducir la velocidad de impresión, Puede girar el saber en la pantalla LCD. Como se puede ver en la tercera línea de la pantalla LCD, "FR 100%" is default printing speed. Stellar Futures Delta Exchange
Traduzco del Inglés al Español en Google traducir, espero obtendrá mi punto.
thankyou so much!!
