How to slove the problem of MAX/MIN TEMP error(GT2560)
Re: How to slove the problem of MAX/MIN TEMP error(GT2560)
Post by William » Mon Oct 21, 2019 10:16 am
Have you tried the above solution to try?
TheHyperion
Post by TheHyperion » Mon Oct 21, 2019 10:32 am
The above is not a solution. The above only helps to identify a faulty thermistor. I don't have faulty thermistors. This error only occurred after a firmware upgrade.
There is an error in the firmware you have provided.
I have used the instructions and te I3 Pro C firmware shows the termistors are all working at room temp.
But when I load the G2S firmware on, they all read 0.
lynxys77
Post by lynxys77 » Wed Apr 08, 2020 7:12 pm
when I disconnect the thermistor cable, I have -14/0 and when I reconnect I have 358/0, is the motherboard defective?
Post by William » Thu Apr 09, 2020 9:25 am
Hi, if this.
it is the hotbed thermistor problem.
You need to replace it.
magy357
Post by magy357 » Tue Apr 14, 2020 6:14 am
Got the same problem. Mintemp message, no matter what termistor I plug (checked on another board, working perfectly), always show 0. But in the moment I plug connector in, it flash for split of a second 20°C, then go back to 0.
When I shortcut connector, it show maxtemp, so it's obviously working.
Even I try to solder termistor directly to pin, to be sure for good connection, still show 0.
So I guess the problem is with board, firmware or such. My question is: possible to fix it or need new board?
Post by William » Tue Apr 14, 2020 9:19 am
Hi, If so, there may be a problem with the motherboard,
You can replace it.
MagyG
Post by MagyG » Wed Apr 15, 2020 1:18 am
You can replace it.
Right. Just one question, update firmware would solve it or not? Actually, I have no idea what version is there and how to do it... :roll: :mrgreen:
Post by William » Wed Apr 15, 2020 11:31 am
You can replace it.
Hi,the motherboard cannot be repaired and you need a need a new board.
procreateapp
Post by procreateapp » Wed Jul 21, 2021 5:09 pm
You can replace it.
procreate pc
Kissanimeapk
Post by Kissanimeapk » Mon Sep 20, 2021 4:53 pm
Keep your mind and try to test it. :)
Kissanime app apk
