A20T 3 in 1 Hotend
BreeOge
A20T 3 in 1 Hotend
Post by BreeOge » Tue Jul 27, 2021 3:03 am
Does the 3 in 1 hotend have Teflon tubes inside separate from the tubes attaching to the hotend. I noticed on some blending hotends they recommend replacing the internal tubes due to they melt and will cause blockage, or change them out with Capricorn tubing that can handle higher heat. I was wondering if the 3 in 1, has such tubes?
Thank you
Admin
Re: A20T 3 in 1 Hotend
Post by Admin » Tue Jul 27, 2021 2:57 pm
Hello, the hotend structure of A20T is the Teflon tube directly into the hotend, not separate.
