how to troubleshoot when Sanguinololu not heating
Sherry
Post by Sherry » Fri Oct 30, 2015 11:01 am
1.Extruder/Hotbed is not heating
This is the SCH of extruder & hot bed heater
Q1 is hot end mosfet,Q2 is hot bed mosfet.
1. Firstly, let us check power supply outputs. Some people use host power supply whose one of output is 5V which can’t support hotend/hotbed to heat obviously.
Then checking whether the 12V DC could power up the mainboard or not.
①Only plug USB without 12V DC, the power LED is lighted.
②Only turn on 12V DC without USB. The LED is lighted as well.
If not,The 12V DC is not turn on or broken;
Or L7805 is broken.
power led.jpg (26.05 KiB) Viewed 40311 times
2. Secondly, checking if the mainboard temp reading and thermistors are good. Sometimes the LCD is not sensitive, please reset the LCD panel before reading LCD every time.
1) Make the both thermistor slots open circuit. The LCD will display 0/0, 0/0, MIN TEMP.
open circuit.png (677.32 KiB) Viewed 40311 times
2) Make the both thermistor slots short circuit by plugging jumper caps. The LCD will display 358/0,358/0 , MAXTEMP.
short circuit.png (389.74 KiB) Viewed 40311 times
3) Plug thermistors.it will display room temperature/0, room temperature/0.
3. Thirdly, let us check whether the resistance of hot bed and hot end are normal.
Tip:Please short out the red and black probe at first, you can read a internal resistance. To get a more accurate resistance. The internal resistance should be subtracted from the resistance you measure next.
internal resistance.png (435.02 KiB) Viewed 40311 times
Hot end: it’s resistance is 3.8ohms. 3.8 minus 0.3 is 3.5ohms.
Tip: please let probe tips touch metal carbonyl conducting layer inside insulation material.
hot end resistance.jpg (77.35 KiB) Viewed 40310 times
Hot bed: it’s resistance is 1-2ohms.
Here is two type of hot bed: MK2A&MK2B
hot bed(MK2A).png (610.39 KiB) Viewed 40310 times
hot bed(MK2B).png (830.33 KiB) Viewed 40310 times
4. Finally, let us check their MOSFETS.
Please plug both hot end heating wire and hot bed’s.
Tip: Make the metal carbonyl conducting layer of heat cables be in good contact with slots. Otherwise the following test will be fail.
When not heating
VH_END=0V.
VH_BED=0V.
hot bed mosfet(no heating).jpg (130.27 KiB) Viewed 40310 times
When heating, MOSFET are breakover.
VH_END=10.88V.
VH_BED=10.61V.
hot end mosfet.jpg (128.23 KiB) Viewed 40304 times
hot bed mosfet.png (924.64 KiB) Viewed 38496 times
Extruder is overheat
1. Checking if the outputs of power supply are over 12V.
2. Checking if mainboard can read correct temperature and the both thermistor are good.
3. Maybe MOSFET is out of control. In other words, the MOSFET is always on even if it reach the temperature you have set.
In this case, please check if there is short circuit in mainboard.
over heat.jpg (168.02 KiB) Viewed 38496 times
soniyasheelu7738
Re: how to troubleshoot when Sanguinololu not heating
Post by soniyasheelu7738 » Wed Jan 16, 2019 8:08 pm
That's a definitely bad, as this will short the output from the transistors, it shouldn't damage them though.
It is possible to get insulation washers, to put between the transistors and the hotend, but the easy solution is to just detach the hotend transistor from the heatsink (it shouldnt really get hot), and make sure it doesn't touch the heatsink. Use some tape, to isolate it.
But you really should isolate the transistor from the heatsink, to minimize the risk for shorting the output.
Post by William » Wed Jan 16, 2019 11:42 pm
Your point is correct and clear!
hakkubaba
Post by hakkubaba » Tue Jan 29, 2019 5:34 am
I am an electrical engineer and thats a complicated problem that you have it is looking worst from my point of view for your system. Make the help of epople who you thing a trend expert in the meidum to undo some things that will make it ease for the people who are going to face it.
farhkh
Post by farhkh » Mon Mar 23, 2020 2:15 am
it happened with me too, but now working fine.
Farhantech
Stevesmith
Post by Stevesmith » Mon Mar 30, 2020 9:17 pm
https://www.inthow.com/
[url]
https://firedout.com/
https://techfela.com/
https://2into.com/
https://techimpose.com/
https://distantinfo.com/[/url]
This build a pc sales is dedicated to provide Xender Download official links for Android, iPhone as well as Windows PC. Free Download Xender App as it is really amazing mobile app which allows file transfer between all type of devices including iptv stalker kodi & MacYou can even download Xender APK Android file, please keep on reading to know how to easily get Xender Free Download.Xender App is one of the best way to transfer or send/receive files between how to install elysium on kodi and it is officially available for Android as well as iPhone and recently this app got new release i.e tinkle pad for PC or Web, with the help of this feature users will be able to transfer files between phone and computer almost instantly. This makes it All in one file transfer and sharing app for users.This complete website is dedicated for providing guides and proper links to Download fusion tvaddons app on Android, iPhone as well as Windows PC. Xender Download is available below, please keep on reading.The new space mov Connect PC feature is so amazing that it will transfer all the things which you need between your smartphone and computer (on Windows, Mac as well as Chromebook) without any issue.
Stevesmith
Post by Stevesmith » Mon Mar 30, 2020 9:19 pm
1337 unblocked for Mac is a free app that you can easily download Unblock Fmovies and install on your iMac or MacBook computer.With it, you can connect to different devices and transfer files over a wireless LAN connection.Once you have downloaded and installed the file on your computer, you can start using the application to transfer or receive files. The biggest advantage is that alluc for kodi can connect to any device from any platform. The iso hunt proxy allows us to send or receive files at a speed of more than 20 Mbps, something incredible. This high speed makes it easy to send or receive large data in a very short period of time.Perhaps this is the great advantage of axxo movies, and in addition to working on almost any platform, 1channel repo is not necessary to have the same type of device to be able to connect between them. Both devices will connect only if both devices are connected to the same wireless network or to the same wireless router.
McCabe1N
Post by McCabe1N » Fri Dec 04, 2020 8:04 pm
I am having connectivity problems with my board MyBalanceNow.
