Geetech Prusa i3 Pro A - Z Axis Problem!!
Posted: Sat Oct 26, 2019 5:03 am
Hello
I'm having problems with my Z Axis. It seems that sometimes one of the two motors is "stuck" and then only one of them moves,
so everything is getting messed up.
after a 10mm height of printing I measured the difference between the two motors and it reached up to 3mm.
By Stuck I mean that I hear like a weird clicking noise, it tries to rotate but not successful.
I did check the height of each motor at start (Home position) and it's the same position (0.1mm resolution caliper).
Help???fedloan irs.gov easybib
