here is the VS1053 module pinout description:
5V - 5V power line
GND - ground power line
CS - SD card chip selector
MISO - SPI bus MISO signal common for the VS1053 chip and the SD card
SI - SPI bus MOSI signal common for the VS1053 chip and the SD card
SCK - SPI bus CLK signal common for the VS1053 chip and the SD card
XCS - VS1053 chip selector for command interface
XRESET - VS1053 chip asynchronous reset
XDCS - VS1053 chip selector for data interface
DREQ - VS1053 chip data request signal
So from the above you can see that this module uses common SPI bus for the VS1053 chip and the SD card. As a downside of this connection, the VS1053 chip communication will be disrupted by the card initialization when it's inserted or removed. For more details about this downside see this post.
Hope this helps somebody.
Cheers
VS1053 - Module pinout description
Jump to
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
