I have a GT2560 board from 2015 with not a lot of time on it. It is on my i3 Prob kit I built. I updated the firmware to 1.1.9 so I could add a BL Touch in the future and to be able to use Linear Advance.
I was having trouble with my part cooling fan and was able to finally figure out what was going on in the firmware to get it going again.
While I was tweaking firmware and doing pid tuning I noticed all my fans stopped working? Q5 is still receiving a signal and it varies with speed adjustment from .5 - 5 volts. I have looked at the schematic for the board but am having trouble determining where the voltage regulator is that supplies the 12 volts for the fans. I disconnected everything from the board except the power cable and measured the voltage at the fan pins. I get 10.3 volts. When I connect a fan they all drop to 3.7 volts?
I was wondering if someone could tell me where in the circuit is the 12 volt regulator for the fans? I see an 1117l-3.3 low dropout linear regulator that supplies 3.3 volts. I see an LM358 opp amp but no regulator?
I have spent a considerable amount of time on this printer doing upgrades and getting the firmware working correctly. At this point it is starting to nickel and dime me or I would just buy a newer board.
Any help here would be most appreciated,
JKCAB
Voltage regulator for fans
Jump to
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
