E3D PT100 Temperature Sensor on GT2560 rev A
Keffer
Post by Keffer » Fri Oct 12, 2018 4:40 am
I am having trouble with my E3D PT100 temperature sensor when it is connected to my GT2560 board. If I disconnect the amplifier from the GT2560 I get exactly what I should, 1.211 volts. When I connect the temperature sensor to the GT2560 it changes to 1.289 volts. This throws my temperature off by 17 degrees c. I am using Marlin 1.1.9 table 20 for the PT100. Is there a different table I should use? Is there a reason the voltage changes? Any help would be appreciated. Thanks.
Re: E3D PT100 Temperature Sensor on GT2560 rev A
Post by _kaktus_ » Fri Oct 12, 2018 11:54 am
Hello.
Is it possible that you have an element with the wrong resistance? Other type?
Otherwise you would have to use offset in the code.
Keffer
Post by Keffer » Fri Oct 12, 2018 9:17 pm
I could see the sensor being wrong if I didn't get the right voltage value with the amplifier disconnected. It's the change in voltage when it is connected that is the problem. E3D is sending me a new sensor and amplifier to see if that is the issue and I will update this post when I try this out.
Keffer
Post by Keffer » Wed Oct 17, 2018 3:01 am
Received the new PT100 sensor and amplifier board from e3d and have pretty much the same results. 1.119 volts with the signal pin not plugged in and 1.278 volts with it plugged into temp0 input pin. The power for the amplifier is being taken from the modified Y max input (changed connector to get the +5v and ground) The voltage to the amplifier board is 5.00 volts. Something is shifting the output up and I can't figure out what. I could just offset table 20 in marlin for the different voltage but I don't know if this would be linear. Any ideas?
michaelharney
Post by michaelharney » Tue Jul 14, 2020 8:53 pm
1.119 volts with the signal pin not plugged in. I couldn't figure out what has shifted the output.
airgunmaniac
Pigman
Post by Pigman » Mon Nov 16, 2020 4:35 pm
Temperature sensor (allicdata) refers to a sensor that can sense temperature and convert it into a usable output signal. Temperature sensor is the core part of temperature measuring instrument, and there are many varieties. According to the measurement method, it can be divided into two types: contact type and non-contact type. According to the characteristics of sensor materials and electronic components, it can be divided into two types: thermal resistance and thermocouple.
Pigman
Post by Pigman » Mon Nov 16, 2020 4:36 pm
lisaaktar012
Post by lisaaktar012 » Sun Sep 26, 2021 12:54 am
There are lots of information in the net that could make you feel overwhelmed but in Air Gun Maniac you can discover any details you need, from air rifle reviews to air gun buying guide. The site consists of unbiased and sure info that helps you make the supreme decision to realize the air rifle that suits you most.
gun safes reviews gunsafeshub
Automobiles news autogyd
