Cold Extrude will not disable
mike.h99
Post by mike.h99 » Mon Jun 07, 2021 10:28 pm
I wantto use my A30pro with a modified hotend to print chocolate.
The extruder motor will not operate at the low hot end temperature of 30 degrees
I am unable to make the M302 P1 S0 cold extrude have any effect when sent directly using repetier-host
The printer also gives little information in the Log Window of Repetier. ( Echo) M111 appears ineffective.
The printer tells me it has firmware version V1.01.01 and hardware version v1.7
The M302 P1 S0 works fine on my Geeetech Pro C
Marlin/Smartto problem ? Which command should I use to disable cold extrusion checking.
I dont want to try and change the source files.
