Temperature issue
akshakimos6
Temperature issue
Post by akshakimos6 » Fri Aug 27, 2021 10:25 pm
Hello everybody,
I just bought an A20M and printed successfully the example inside the SD card. Then I followed the manual to import the settings (both of printer - first part of 6.2 manual's section - and filament - Geeetech A20M PLA high.rcp - as well. Now I downloaded an stl file from thingverse and opened with repetier, using the settings just imported, then I sliced it with curaengine and exported it with "save for sd print'" copying file to the sd. But once inserted and started printing printer heats only bed not extruder (that is still on 0) so when bed is warm enogh printer gives "temp too low". It seems to be a problem in the file but I do not understand why, because I followed all the steps inside the manual!https://nox.tips/ https://xender.vip/
SharonHarvey
Re: Temperature issue
Post by SharonHarvey » Thu Sep 02, 2021 3:13 am
I can see that you are an expert at your field! I am launching a website soon, and your information buying a research paper for college will be very useful for me.. Thanks for all your help and wishing you all the success in your business.
BreeOge
Post by BreeOge » Thu Sep 02, 2021 11:14 pm
Look at the G-Code in the file that you put on the flash. You should have a M104 and/or M109. Here is a link to all the Gcodes in Marlin firmware.
https://marlinfw.org/meta/gcode/
