Hi there. I've been a happy A20M owner until I upgraded last version of 4.8 Cura...
Never understood this printer concept, I always had to use Color Mixer plugin in order to be able to print.
Never used two color, just the same filament on both feeders. I would always use Color Mixer to modify the gcode so both feeders would work at 50%.
Now, after processing with Color Mixer, only 1 feeder will work, and at the same speed, so 50% of the material is used and the prints are wrong, no adhesion, etc... The display on the A20 will show 100% 0% while before displayed 50% 50%...
Since it's just on one extruder, I tried to increase flow to 200%, but the value stays orange, I guess can't go so high....
So please, someone explain me. If I want to print single color and use Cura, how can I do it without using Color Mixer? Specially now that is not working the same way it did....
I thought 1 feeder working at 100% would be enough for normal prints. Is there something I'm missing?
Thanks.
Normal printing. 1 or 2 extruders.
Jump to
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
