Easyprint software for WINDOWS
Re: Easyprint software for WINDOWS
Post by William » Fri Jan 04, 2019 9:19 am
bertie wrote:
Sat Dec 29, 2018 3:03 pm
I solved it by manually downloading and installing Visual C++ Redistributable 2015 (X86 + X64) from Microsofts website and reinstalling EasyPrint. Installing C++ via EasyPrint installer did not work for me and on my machine was only version 2017 instead of 2015.
Thx for your feedback! ;)
pepgra
Post by pepgra » Sat Jan 05, 2019 5:19 am
Because the combo-box does not show the model A20M?
Bernhard
Post by Bernhard » Sun Jan 06, 2019 8:18 pm
I installed the Easyprint software. I can load the 3D-files but I cannot save it as G-code.
There comes following failure notice: File C:\Users\Bernhard\AppData\Roaming\easyprint\work\composition.gcode was not found.
How can I get this file?
I use Windows 7 and Easyprint 1.2.6
Best regards
nvnazeer
Post by nvnazeer » Mon Jan 07, 2019 12:35 am
Hi, where can i get a link for the latest version of easyprint software for windows.
Are there any issues if i use this with A10M
Post by _kaktus_ » Thu Jan 10, 2019 1:55 am
:mrgreen:
nvnazeer
Your question should not be asked at all. :roll:
The answer is in the first post of this topic.
If you are an attentive observer you will see a location there: https://www.geeetech.com/firmware/
As of today, the latest version has been announced 2018-09-06.
Achim2019
Post by Achim2019 » Thu Jan 17, 2019 4:08 am
Hi, I'm new here. I miss the download button for Easyprint Software, english version.
Thx in advance!
WikiBrikoFix
Post by WikiBrikoFix » Sat Feb 02, 2019 5:23 am
For all that have problems with EasyPrint 3D: the correct installation procedure is
1) Remove all C++ Redistributable version 2015 and 2017
2) Manual install the C++ Redistributable 2015 for x86 and x64 downloaded from here
https://www.microsoft.com/en-us/downloa ... x?id=52685
3) Install EasyPrint 3D (custom install, deselect C++ 2015 Redistributable packages)
4) reinstall C++ Redistributable 2017 removed on step 1
https://support.microsoft.com/it-it/hel ... -downloads
I have done it, after many problems, and now EasyPrint run correctly, without cura engine error and save error.
bye!
Post by William » Wed Feb 13, 2019 1:22 pm
bye!
Thanks for sharing your experience!
schlulou
Post by schlulou » Sat Mar 23, 2019 3:05 am
Is this software still being worked on or can it be considered abandoned? What's the latest version? Too many sources to keep track of. Forum, apache listing, download section etc. My Version has no idea the A10M exists...
Post by William » Tue Mar 26, 2019 2:22 pm
Geeetech official won't updates EP, I recommended you to use Cura, Slic3r, etc.
Locked
Users browsing this forum: No registered users and 9 guests
