sundogz
Post by sundogz » Thu Jun 13, 2019 11:31 pm
I have one of the first Acrylic I3 ProB printers and my hotend now heats 35-40 degrees higher that it's set for. I've changed thermistors twice with no joy - so swapped boards thinking it was the firmware. But the the problem with hotend is still there, and the new board must be for the T8 rods (mine has the M10's) - the Z just crawls a couple inches and stops. I don't know how to set it - the LCD 'load' and 'save' features reset after power down.
Do you have the old version of firmware available or can tell me how to check set this. I have gone over the Arduino thread but guess I am not smart enough. :shock: I use this printer every day and miss it. I hope you can help
TribunXy
Post by TribunXy » Mon Jul 01, 2019 2:52 pm
is it possible to get Marlin 1.1.9 for the Pro W? Or at least a list of the values ​​that have to be changed in the original firmware?
Post by _kaktus_ » Thu Jul 04, 2019 11:51 pm
lauraroz wrote:
Thu Jul 04, 2019 5:04 pm
A mi me vino genial para impresión 3d para regalos de comunión para niños
Admin wrote:
Tue Aug 28, 2018 5:59 pm
Hi,guys!
In order to create a more comfortable discussion environment for forum members.
We have to make some rules,
  1. Mutual respect. Every member should respect each other, which is a prerequisite for mutual discussion. This is like a "mirror". If you don't respect others, we can only tell you with regret: Please leaves this forum!
  2. This forum brings together members from all over the world, so be kind and write in English. This will make it much simpler and easier to search the content.
    Admin 2018-08-26
    Update: 2019-03-02
Marcellus
Post by Marcellus » Wed Jul 10, 2019 3:31 pm
Hello
Please tell us when a new firmware will be released (Geeetech A30) ?!?
Greets
Post by William » Wed Jul 10, 2019 3:42 pm
Thanks for your feedback.
vincentbcd
Post by vincentbcd » Wed Jul 31, 2019 10:38 pm
I surch a firmware for my I3 all aluminium, with GT2560a+, DRV8825,and LCD upper, bed heater aluminium, please.
Do i install firmware with arduino 1.0.1 or can i install it with better, if yes, wich one?
It's the same frame of this.
https://www.geeetech.com/geeetech-prusa ... p-944.html
Thanks a lot for you helping.
Post by William » Thu Aug 01, 2019 9:20 am
Hi, you can refer to this download:http://www.geeetech.com/forum/viewtopic ... 20&t=17046
I hope this can help you.
vincentbcd
Post by vincentbcd » Thu Aug 01, 2019 11:39 am
Thanks William, i heve ever view that, i would day if i can take Arduino younger than 1.0.1.
Re: firmware for geeeteh 3D printers
Post by William » Thu Aug 01, 2019 11:57 am
ZIM372019 wrote:
Wed Jul 31, 2019 11:09 pm
Mark wrote:
Tue Apr 12, 2016 5:35 pm
Don't use the latest arduino version, usually the latest one will cause this problem, it's not the firmware's problem, try to use arduino1.0.1 or arduino 1.5.2.
Hi, iam very new at 3d printing, do i have to download the Ramps file and the Marlin file? or which one do i need? I have the Prusa I3 pro B, and the board is the GT2560, but iam kind of lost, not sure what to do. thanks for the help!
Hi,you can go through the official website: https://www.geeetech.com/download.html?download_id=34
download the HEX file,
connect to the printer and update the firmware via
Cura settings -printer-mange printer.
vincentbcd
Post by vincentbcd » Thu Aug 01, 2019 10:25 pm
Hello William,
Thanks for your helping , it's appreciated.
I have update with new firmware, it s work.... but item was very smaller than real in gcode.
the print area is reduced as well as the object
Locked
Users browsing this forum: No registered users and 12 guests
