Firmware for geeetech 3D printers
Re: Firmware for geeetech 3D printers
Post by William » Tue Apr 16, 2019 10:48 am
Hi,calinb
I have tried to use the Arduino 1.8.3 and it seems ok.
Maybe you can try to use it.
Niyoki
Post by Niyoki » Fri Apr 26, 2019 6:40 pm
I tried to compile Firmware for A10M_marlin1.1.8 with 3dtouch support. But i get Always same errors also tried Arduino 1.8.3 and 1.8.9 also same errors.(There is Arduino Beta 1.9.0 too (some Virus inside ?), because of this didn't installed)).
Do you get Errors too? Should i ignore this errors?
Thanks all.
Niyoki
A10M_marlin1.1.8 & Arduino 1.8.5 errors:
Code: Select all
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28:0,
                 from sketch\MarlinConfig.h:38,
                 from sketch\configuration_store.h:26,
                 from sketch\configuration_store.cpp:190:
sketch\configuration_store.cpp: In static member function 'static bool MarlinSettings::Fixed_parameter_load()':
sketch\configuration_store.cpp:857:19: warning: unknown escape sequence: '\F'
   SERIAL_ECHOPAIR(" \r\Fixed parameter nbytes; crc error ", (uint32_t)stored_crc);
sketch\serial.h:60:40: note: in expansion of macro 'SERIAL_PROTOCOLPAIR'
 #define SERIAL_ECHOPAIR(pre,value)     SERIAL_PROTOCOLPAIR(pre, value)
sketch\configuration_store.cpp:857:3: note: in expansion of macro 'SERIAL_ECHOPAIR'
dga78
Post by dga78 » Thu May 02, 2019 11:54 pm
Hi guys, some help please.
Just got an i3 pro x, followed all the firmware instructions (adriuno 1.0.1, Marlin). All loaded and can connect with repetier through USB but the LCD screen has the two blocked lines. Ive looked at the refresh button and its clear, the code "//" in the flash was correct also. Any ideas?
Niyoki
Post by Niyoki » Sat May 04, 2019 7:02 pm
Hello @dga78,
i don't know about i3 pro X. But for any 3d Printer you must also install under Arduino some libraries (for example A10M Needs Liquidcrystal & u8glib libraries). Maybe you need also some special libraries?
Regards
Niyoki
Roniedson
Post by Roniedson » Sun May 05, 2019 7:22 am
My A10M had firmware 1.1.7, after I upgraded it to 1.1.8 it is giving error "Heating Failed PRINTER HALTED please reset" every time I start printing. Help me, I need to make some impressions.
Niyoki
Post by Niyoki » Sun May 05, 2019 7:11 pm
Hello @Roniedson,
if you are using Cura you must set temperature for both Extruder to the same value everywhere( for example 200 Degree celcius) and also enable Prime Tower for Dual Extrusion.
There is a link:
http://www.geeetech.com/forum/viewtopic ... pdf#p98085
I hope this helps.
I'm using this Firmware https://www.geeetech.com/download.html?version_id=69
from the Geeetech.com / Download / a10M -> A10M_G04(GT2560V3+CH340 Support 3Dtouch) (you can install this over cura while this is a HEX file)
and also this Cura 4.0 files you must put them under C:\Program Files\Ultimaker Cura 4.0\resources Folder (definitions , extruders and materials)
http://www.geeetech.com/forum/viewtopic ... 98&t=62063 (Cura4.0 resources.zip and Geeetech Mixer PLA Profile For Cura.zip)
Regards
Niyoki
Bs2000
Post by Bs2000 » Sat May 11, 2019 6:15 am
Well I see based on forum that the 3dtouch has been promised for the M201 for a long time but yet it hasn't been added. I heard you are no longer making the M201 better😤
Post by _kaktus_ » Sat May 11, 2019 5:41 pm
Bs2000
I've answered your doubts here:
https://www.geeetech.com/forum/viewtopi ... 77&t=61357
Nils
Post by Nils » Mon Jun 10, 2019 10:48 pm
Hello.
In the firmware for the I3 Pro B there is an error so that I can not upload the file to my printer. I use the Arduino software version 1.8.5
Would it be possible that one cares about this issue and informs me as soon as the firmware goes again?
Error code :
exit status 1
using typedef-name 'fpos_t' after 'struct'
The error is in the SdBaseFile.h file
Nils
Post by Nils » Wed Jun 12, 2019 2:31 am
vert wrote:
Tue Jun 11, 2019 10:58 am
Hello.
Error code :
exit status 1
looks like a version incompatibility error
what version of marlin is it as arduino 1.8.5 works with 1.1.8 but not older marlin.
I downloaded an older version of Arduino and that was it. So the firmware versions of the I3 Pro B which are in the forum above are not compatible with the current version of Arduino. Maybe someone can update the firmware to match the current Arduino software
Locked
Users browsing this forum: No registered users and 29 guests
