Blown Fuse on power socket
Viresneaker
Post by Viresneaker » Sun Oct 21, 2018 7:06 pm
Hello I bought my Geeetech I3 Aluminum form Amazon and it worked great until yesterday. (EU-Version)
I printed a case for my power supply and I forgott to take a picture on the cable routing of my switch.
So the result is that the fuse blown on my power socket plug.
My question is which fuse do I need. I know that I need a 250V with a dimension of 5x20 mm but I can't read the current on the fuse.( For me it looks like a 3A fuse).
My second question is if the new cable routing of my switch is correct.
Greetings Viresneaker
Re: Blown Fuse on power socket
Post by _kaktus_ » Sun Oct 21, 2018 10:37 pm
Hello.
Your power supply is on 12V or 24V DC.
Viresneaker
Post by Viresneaker » Mon Oct 22, 2018 4:54 am
Hello
my power supply is 12V 15 A
Here is the picture of the blown fuse in the blue circle
Post by _kaktus_ » Mon Oct 22, 2018 5:05 am
The PSU should have a sticker with parameters.
There should be written a current, which is drawn from the mains at maximum load.
Viresneaker
Post by Viresneaker » Mon Oct 22, 2018 5:30 pm
Hello thank you for the reply.
Input Power supply: 115V/1.5A or 230V/0.75A
So I need a Fuse with 0.75 A?
Or do I need a 10A because it is written on the Plug plastic (250V/10A)
On the blown Fuse is wirtten F_ 3 or 5 / 250V (can't read the current because of bad visibility)
That is why I am so confused what I need to use.
Post by _kaktus_ » Mon Oct 22, 2018 6:05 pm
Hi :mrgreen:
I in your case with a fast fuse 1A 230V AC.
Viresneaker
Post by Viresneaker » Mon Oct 22, 2018 9:00 pm
Thank you for the help :D
Post by _kaktus_ » Tue Oct 23, 2018 2:54 am
