Easyprint software for WINDOWS
SirSunshine
Re: Easyprint software for WINDOWS
Post by SirSunshine » Sun Sep 02, 2018 8:23 pm
Same problem for me as of September. No english version as least from the installer. I got it installed but have no idea what options I've selected. Once installed, it opened in English for me but I could not get it talking.
Post by _kaktus_ » Sun Sep 02, 2018 8:50 pm
And which version of the application do you talk about :?:
SirSunshine
Post by SirSunshine » Sun Sep 02, 2018 11:34 pm
Help > About says 1.2.3
Thanks.
Alex-w
Post by Alex-w » Mon Sep 03, 2018 8:38 am
@SirSunshine Delete configuration folder and then try to install V1.2.6 :geek:
Willem
Post by Willem » Tue Sep 04, 2018 6:28 am
Hey guys!
i'm having some difficulties to make a proper setting in easyjet...
here's my setup:
Win 10 with easyjet 1.2.6
Prusa i3 wood, axis and extruder are calibrated
PLA 1,75mm
seems like the extruder does not apply enough material, see picture.
when i try to set the noozle size to 0,3 mm or 0.3 it automatically sets to 3, same happens when i try to change the retraction.
anyway a print with default settings is very unsatisfying.
btw importing configs is not possible too.
has anyone a clue about this?
2018-09-04 at 00.24.42.jpeg (94.91 KiB) Viewed 131446 times
Post by William » Tue Sep 04, 2018 9:50 am
Hey guys!
here's my setup:
PLA 1,75mm
Have you tried it on repetier-host?
You can download this file then test it
PROW-config.zip
(1.39 KiB) Downloaded 1544 times
Alex-w
Post by Alex-w » Wed Sep 05, 2018 8:35 am
@Willem
Try to set "material flow" :geek:
MarkFish54
Post by MarkFish54 » Thu Sep 06, 2018 12:51 am
Ginko...
This might also be a good place to explain where the "configuration folder" really is....
Post by _kaktus_ » Thu Sep 06, 2018 2:54 am
See here:
Second link.
http://geeetech.com/forum/search.php?ke ... t+app+data
The problem was about something else, but the information remained. :roll:
In different versions of Windows OS, folder changed location. :?
Alex-w
Post by Alex-w » Thu Sep 06, 2018 11:12 am
@MarkFish54
viewtopic.php?f=96&t=61534
FAQ may help you :ugeek:
Locked
Users browsing this forum: No registered users and 21 guests
