My Problem is that My PC(windows 10) Isn't connecting with my Printer.
I had Installed Manually the Driver and Easy Print 3D, but when i go in to Easy print 3D, i can't choose a Com Port.
I can't see the Port in the Device Manager.
Prusa i3 pro W connection to pc Problem.
Re: Prusa i3 pro W connection to pc Problem.
You can refer to this post
viewtopic.php?f=21&t=60612&p=81974#p81974
I had allready tried this. the problem is still there.
it hadn't helped.
Do you know some more idears?
I think this photos would help.
it hadn't helped.
I already tried it and this time again. It is still not working.
Do you have an other Idea.
I hope The Atachments will help to explain.
[attachment=1]Screenshot (2).png[/attachment]
[attachment=2]Screenshot (1).png[/attachment]
[attachment=0]20180403_141642[1].jpg[/attachment]
- I had Downloaded Ch340_EXE for this chip.
- 20180403_141642[1].jpg (287.35 KiB) Viewed 24884 times
- Still I can't choose a Com Port
- Screenshot (2).png (170.64 KiB) Viewed 24884 times
- My Device Manager
- Screenshot (1).png (96.92 KiB) Viewed 24884 times
I had made it now. It was the firewall.
The device manager presents information about the incorrectly installed device.
This is the printer port.
You must try to install the driver correctly. Something has failed before.
Below is a link to download the driver straight from the manufacturer's website.
http://www.wch.cn/download/CH341SER_ZIP.html
;-D
;-D
It sais Code10 Problem. And in Ressoucen is only one thing changeable.
- Screenshot (5).png (279.84 KiB) Viewed 24739 times
