Require full Prusa I3 Aluminium Kit Assembly Instructions
zhangxueyou
Re: Require full Prusa I3 Aluminium Kit Assembly Instruction
Post by zhangxueyou » Fri Feb 13, 2015 10:01 am
Wiring of power supply cable
Wiring of power supply cable.png (281.58 KiB) Viewed 29342 times
Wiring of power supply cable2.png (373.01 KiB) Viewed 29342 times
Wiring of power supply cable3.png (691.46 KiB) Viewed 29342 times
zhangxueyou
Post by zhangxueyou » Fri Feb 13, 2015 10:04 am
Z motor (2 in all)
Z motor(2 in all).png (535.02 KiB) Viewed 29342 times
Z motor(2 in all)2.png (435.72 KiB) Viewed 29342 times
Wiring of Z motor.png (515.74 KiB) Viewed 29342 times
Admin
Post by Admin » Fri Feb 13, 2015 10:49 am
Wiring of Z motor
Wiring of Z motor3.png (422.18 KiB) Viewed 29341 times
Wiring of Z motor2.png (426.99 KiB) Viewed 29341 times
Wiring of Z motor4.png (792.78 KiB) Viewed 29341 times
The pictures above are all the wiring of each part. Hope it will help you successfully complete it.
Anabatix
Post by Anabatix » Tue Feb 17, 2015 7:36 am
Thank you this has been a big improvement.
Did you also send the replacement LCD as promised?
http://www.geeetech.com/reprap-ramps-v1 ... p-615.html
It is the only thing missing from finishing my project.
I did notice some small errors in your wiring perhaps.
1. The Z axis can not be wired like that unless you supply in your kit 2 extra wires. The plugs on Z axis board would not fit without thinner plug adaptor.
2. End stop wiring is different to RepRap project pin positions. So I will try Reprap wiring diagram first. And it depends on if they are for minimum or maximum end stop position.What are your thoughts?
Reference http://reprap.org/wiki/Prusa_i3_Rework_ ... ors_wiring
Kind regards
Lee
From Reprap site: http://reprap.org/wiki/Prusa_i3_Rework_Electronics_and_wiring#Thermistors_wiringhttp://reprap.org/wiki/Prusa_i3_Rework_Electronics_and_wiring#Thermistors_wiring
Screen Shot 2015-02-17 at 12.33.31 pm.png (124.17 KiB) Viewed 29322 times
Admin
Post by Admin » Tue Feb 17, 2015 8:38 am
1. There is no enough zone to plug Z motor directly. So we add Dupont wire, can you see that in the picture?
2. I am so sorry for this, because I am new guy. I need time to know these things step by step. So please forgive my fault. And thank you for your tips.
Good luck!
Anabatix
Post by Anabatix » Tue Feb 17, 2015 8:51 am
Yes the photos were a good help. The Dupont wire was not in the kit so I had to order some from a local supplier.
Did anyone send the missing LCD controller? Can you check for me please.
Thank you for all your help.
My printer is looking very good now.
Regards Lee
Admin
Post by Admin » Tue Feb 17, 2015 8:57 am
We have sent the missing LCD to you last week. It takes about 5-10 days. Please be wait patiently.
Anabatix
Post by Anabatix » Tue Feb 17, 2015 9:02 am
:mrgreen: Excellent.
Have a great day!
Admin
Post by Admin » Tue Feb 17, 2015 9:06 am
Good luck!
Anabatix
Post by Anabatix » Tue Feb 17, 2015 10:52 am
:D I just check my mailbox and the LCD parts are sitting there waiting for me!
That was super fast, many thanks.
Lee
