I have problem with my melzi ardentissimo tha t i bougt by Evelina Deng.
It have no light on LED! is it OK?
I assume there is no Bootloader Installed(?( it have atmega644P 20
I cannot uppload anything to it. I use DAPA and Arduino IDE1.0.5 with your IDE help files installed in hardware in arduino.
when trying uppload bootloader it says AVR device not responding. device signature 0x000000
PLease help!
i opened a dispiute on this one yesterday.....
MELZI trouble
Re: MELZI trouble
Hi, this module has no LED.
what is your OS? Linux or MAC,or Windows? It’s not support Linux and MAC.
and have you install driver? have you find your port in device manager? and what is your complier?
Note: 32 bit and 64bit driver.
Re: MELZI trouble
Win xp diamond.
Is bootloader preinstalled?
It shows up as com 6. In arduino IDE> tools> serial ports.
Driver? I have teensyu serial port istalled. As firmware i wanted repetier. Is that ok? That one sugest atmega1280 for melzi.. 644p is sugested to sanguonololu.
Re: MELZI trouble
Win xp diamond.
In arduino IDE1.0.5 it shows up asCOM 6.
Compiler? Arduino mentined above. Tried load bootoade by a hombuilt parallell programmer (DAPA)
I want repetier firmware bu it have only atmega1248 preloaded for melzi.my have atmega644p.
Re: MELZI trouble
Win Xp diamond
Driver?
Compile with arduino IDE 1.0.5
tried to load bootloader with arduino and parallell programmer DAPA..
no response
Driver?
no response
Re: MELZI trouble
It has preinstalled bootloader,I don't have to uppload it!
Re: MELZI trouble
Thanks for that information. Then is the question what is wrong. Because i cannot uppload any firmware, nor sketches like tiny arduino "blink" ...
Still belive it is transport damage due to poor package. Two wraps bouble plastic and then put in a box of 20x30x5 cm that when arrived had the measure of 30x30x2 cm.
Re: MELZI trouble
hi
you can try it like this:
1. The auto - reset jumper cap not inserted
2. The external power supply didn't answer, PWRS jumper cap didn't choose to usb power supply. External power supply connected but PWRS jumper cap connectto the usb power supply
3.74 hc4050d chip broken or didn't weld well
4. The driver didn't pack good, can't find the com, the board didn't choose the right, should choose to sanguino w/ATMEGA644P
Re: MELZI trouble
Hello now iv'echecked upp your solutions
1 autoreset jumper tested bot in place and not in place. no difference!!
2 if usb\pwr juper is not in place it des\nt detect board as com6 . so it must work..
3 both chip 4050D and ftdi 232 looks alright and well soldered in a weak magnifier.
4 sanguino w atmega 644p choosen.
this is what i get then when trying uppload arduino blink sketch..
any idea what to do next?
Thing is ,i got an sanguinlolou 1.3a self soldered exept ftdi chip swaped by expert.
It behaves exactly the same. and i have tried both on another notebook with Win xp home.. mayby try it an a vista desktop too?
Re: MELZI trouble
hi
may be your IDE version is not correctly.please contact us and we will provide you IDE.my email is technical@geeetech.com
