Newly updated Firmware V1.0.5 for Prusa I3 M201
RoshniShuklaa
Re: Newly updated Firmware V1.0.5 for Prusa I3 M201
Post by RoshniShuklaa » Fri Dec 04, 2020 4:27 pm
Anyone know if the new v1.0.4 fixed the long print(1,000,000) Line+1 issue? omegle I haven't loaded the firmware yet, but I wanna know if it will fix this issue before I have to move the printer for update.
stprofesional
Post by stprofesional » Wed May 12, 2021 9:35 pm
I buy an used Geeetech Prusa I3 M201 with the GMT32 Rev B board.
I update to the firmware to V1.0.5.
I change the threaded rod T 8mm and change the Z resolution movement.
But the reset of Z is wrong, when it reaches the sensor the first time it detects it, it goes up and when it goes down again it passes, as if the sensor was not working.
Thank you
