Unresponssive printer and crc errors
Panormitis
Post by Panormitis » Mon Jan 13, 2020 4:03 pm
Hello, I have a Geeetech A10M for about a year. It was working fine. I tinkered and uploaded the firmware numerous times in the past with no problems.
However after the last firmware install, the printer became unresponsive and throws a lot of crc errors. Any ideas how to fix it?
Code: Select all
echo: External Reset
Marlin 1.1.8
echo: Last Updated: 2017-12-25 12:00 | Author: (none, default config)
echo:Compiled: Jan 13 2020
echo: Free Memory: 2432  PlannerBufferBytes: 1360
echo:V12 stored settings retrieved (642 bytes; crc 36404)
echo:poweroff stored settings retrieved (56 bytes; crc 0)
read file dir:
read file name:
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
crc error: 10 != 0
Re: Unresponssive printer and crc errors
Post by William » Mon Jan 13, 2020 4:21 pm
:D Hi,you can try to :1.Go to the octoprint settings;
2.In the settings under Serial connection -> Behavior -> Cancel current print jobs and then execute M500 in the terminal.
and you can refer to this:https://github.com/OctoPrint/OctoPrint- ... /issues/42
I hope this can help you.
Panormitis
Post by Panormitis » Mon Jan 13, 2020 4:29 pm
I tried other versions of firmware, I tried upgrading with and without an sd card. Didn't make any difference. I tried M502 & M500, no luck.
The screen & menus are unusable.
How many rewrites can the eeprom handle?
I'm not using octoprint
Post by William » Mon Jan 13, 2020 4:44 pm
Hi, Can you upload it using the firmware that has been compiled on the official website?
Upload using firmware toolkit,
You can refer to: viewtopic.php?f=20&t=69684
You need to close the slicing software when uploading to avoid occupying the port.
Panormitis
Post by Panormitis » Tue Jan 14, 2020 10:40 am
I usually upgrade the firmware from Linux using Arduino IDE, with no issues so far. However when I used Windows and the firmware toolkit, the printer worked again, thanks.
I guess something went wrong with the usb drivers on Linux.
I have another problem too, I'll open a new thread for it.
Panormitis
Post by Panormitis » Wed Jan 15, 2020 7:59 am
Thanks for the info Vert
