install 3D touch how to?
Re: install 3D touch how to?
Post by William » Fri Sep 27, 2019 9:16 am
:D Hi,keen.
You need to fix the 3d touch on the printer and then adjust it.
Then brush in the firmware with 3d touch.
and like this:https://www.youtube.com/watch?v=_RtsZDbR2po
It's a guide.
I hope this can help you.
Jarda3d
Post by Jarda3d » Tue Oct 01, 2019 5:46 am
A10/M are good and stable printers and did not need everyday adjustmenst of build plate, if they are correctly tightened and angled. Chinese hands are small and they have small torque, you need to tight all screws by your own. Did not adjust the right side of Z axis of course, it need to be loose.
After first cca 20-30 hours your printer is stabilized and did not need more build plate adjustments. My last adjustments was about 4 months ago after 500km trip in car, assembled of course.
A10 Slic3r profile: here
