The Mac version doesn't work with Catalina !
An update please
Color mixing software for multi-mixing printer
Re: Color mixing software for multi-mixing printer
Hi, Can you open the color mix when you use this system?
Can you describe your situation specifically?
Catalina needs 64 bits applications, I thing it's the problem
- Capture d’écran 2019-11-18 à 15.44.07.png (100.06 KiB) Viewed 24142 times
You need to run a chmod command in the terminal in order to be able to open the app.
