GeeeTech Color Mixing Software does not change the G Code
Re: GeeeTech Color Mixing Software does not change the G Code
Post by William » Thu Mar 07, 2019 10:04 am
Hi,Jorgie
1. I set the thickness is the 0.4mm with no top layer
2. When I import the gcode from Cura,it shows 60K lines(Vase mode won't show layers but show lines)
3.If you don't want to upload the gcode or any pic.
Then we can't refer to it and we can't give you more help.
Kindly
Jorgie
Post by Jorgie » Thu Mar 07, 2019 6:08 pm
Ok, here is the output G code.
vase_colored1.zip
(546.04 KiB) Downloaded 629 times
Post by William » Thu Mar 07, 2019 10:23 pm
Thanks!I will check it when I get up.
Jorgie
Post by Jorgie » Sun Mar 17, 2019 12:23 pm
Hi William,
What did you find?
Post by William » Mon Mar 18, 2019 1:41 pm
Today I have the time for a test.
Will let you know later.
Jorgie
Post by Jorgie » Mon Mar 25, 2019 2:54 pm
Hi William,
Do you have an update? While not an urgent issue, it would be nice to have an answer as to why it worked for you but not me.
Sean
Post by William » Mon Mar 25, 2019 5:58 pm
I've fixed it.
I tried to replaced the "G0 Z0.15" to "G1 Z0.15 F400" then it worked.
You can refer to it:
Jorgie
Post by Jorgie » Mon Mar 25, 2019 6:06 pm
Hi William,
So you have analysed the G code and fixed it. BUT that means the GeeeTech Color Mixing Software is faulty. Correct? LOL
Post by William » Mon Mar 25, 2019 6:12 pm
Completely correct!
It is a bug of the color-mixer.
I will talk it with the author.
Thx for your feedback!
k20human
Post by k20human » Sun Jan 05, 2020 2:49 am
I have same problem with Color Mixer 1.1
I slice the STL with Cura 4.3
Please find GCODE in attachment
This is the orignal model : https://www.thingiverse.com/thing:2431575/files (slime)
I try others STL, sometimes it works, sometime not :(
G_Fire_Slime.zip
(600.2 KiB) Downloaded 563 times
