Getting "mintemp triggered system stopped" in Repetier
simonjo
Post by simonjo » Sun May 05, 2019 6:25 am
I built my i3 Aluminum not to the full extent as I don't want to use it as a 3D printer. I left out the heated bed and the extruder, so above error will be due to these missing components.
Can anyone tell me how to bypass this in some way.
My intention is twofold:
1) use the extruder stepper to drive a syringe mounted on the extruder carriage, for the purpose of dispensing solder paste
2) mount a milling head on the carriage (connected via a flex to a small milling motor) for the purpose of milling plastic housings
Any help would be welcome.
thx
simonjo
Re: Getting "mintemp triggered system stopped" in Repetier
Post by simonjo » Sun May 05, 2019 4:39 pm
Solved by attaching the temparature sensors
Now still need to figure out why Y axis is limited to 150mm and Z axis limited to 100mm
And what "Fr" in the info screen of the LCD display means
Post by _kaktus_ » Sat May 11, 2019 8:12 pm
Hi.
:mrgreen:
FR is a print speed that you can modify to a certain extent. ;)
Changing the setting affects real-time printing.
Users browsing this forum: No registered users and 1 guest
