I have the aluminum i3. When I set my value for the zstep/mm, the controller won't keep the value I've set. If I back out of programming, or if I shut off the unit, it just defaults at 2560...
Also, when the unit is on for 4 or 5 minutes, my screen goes garbled. I have to unplug the machine to get it to reset....
I've updated the firmware, but nothing...
Aluminum Prusa i3 Memory Issues
- 2018-12-09 04.04.29.jpg (211.68 KiB) Viewed 1717 times
Re: Aluminum Prusa i3 Memory Issues
Hello.
Can you show a photo of how you laid the cables?
Also the cables to the display module.
1.Try to restart the printer
2.Try to check the wires short circuit or not
I had a garbled screen when the power was off but the USB cable was plugged into the socket and a laptop.
The board GT2560A can use the power of the USB.You can remove it then restart it
