Upgrade from 1.0.1 to 1.0.5 gives 2 lines BLOCK display
Tparent
Post by Tparent » Mon Jul 22, 2019 1:18 am
Just assembled my brand new M201.
Trying to challenge mu i3 pro C which is working like a charm but with a limited printing volume.
Everything worked as expected untit I tried to upgrade in V1.0.5.
Board is the new/last GTM32 VB.
-> connecting, putting jumper, loading and verifying FW loaded in the board is working well.
but... Display stay with 2 lines of block without giving me back the control using the button.
After some research and thanks to the forum :
-> loading last .bin version (1.0.4, available in a separate post) with 8002000 as parameter + erase global memory
AND afterwards
-> loading bootloader 1.0.1.bin address 8000000 erase only used memory
is gving me back the control on the printer (display + button working as expected)
Stay one question, how could I upload the V1.0.5.hex (last version) and make it works ?
Updating by uploading it with address 8000000 (grayed no passibility to change) and erase only used memory page doesn't work
All idea / suggestions are welcome..
Thank you so much
(+3 x Kossel)
Mostly PLA
Re: Upgrade from 1.0.1 to 1.0.5 gives 2 lines BLOCK display
Post by _kaktus_ » Mon Jul 22, 2019 2:41 am
Hey Hey
When I read your post, I laughed at your little child. :lol:
Your situation is amazing.
I will help you in an inappropriate way, - by asking a question :!:
Or maybe two. ;)
It seems to me that on this forum has been clearly stated that the firmware v 1.0.04 is today the last release,to the controller board GTM32Pro vB. Or maybe I'm wrong and you know something new for me?
What tempted you to upload versions marked v 1.0.05 :?:
To which version of the controller's board is firmware marked v 1.0.05 :?:
Tparent
Post by Tparent » Mon Jul 22, 2019 5:30 am
Hey !
Firmware page is maybe a little bit cryptic :-)
Thanksfully a between bracket "(for GTM32)" is supposed to make the difference between the pro and the "not pro" (too bad, the not pro seems to be more powerful than the pro. :lol:
Firmware Page :
1) Firmware for Prusa I3 M201
For the new board(GTM32 Pro VB)on M201:
M201_V1.0.01.rar
(58.24 KiB) Downloaded 1879 times
gtm32_machine_m201.zip
(62.23 KiB) Downloaded 4911 times
The latest version(for GTM32) :
GTM32_V1.0.5.zip
GTM32_V1.0.5
(98.94 KiB) Downloaded 9009 times
(+3 x Kossel)
Mostly PLA
Tparent
Post by Tparent » Mon Jul 22, 2019 5:33 am
Nice the red color "(GTM32)" definitively help to understand the difference / border line between the two boards :D
Have a great day
(+3 x Kossel)
Mostly PLA
Post by _kaktus_ » Mon Jul 22, 2019 3:40 pm
Hi.
A new user must know his hardware and be able to identify it correctly. :idea:
Fortunately, when you have GT branded products, it is not difficult.
Each controller board is legibly signed. You just need to look for the signature and read it. ;)
At the turn of the century, when the M201 was manufactured, its controller board was improved.
The first produced unit - it was a few years ago, had a different controller than the M201 sold now.
If you look at it carefully and do not act in a hurry, you will understand.
Otherwise, you will make more mistakes in the future.
I guess you have a GTM32 Pro vB controller model.
Below are images of older versions of the controller. These are GTM32 vA and GTM32 vB.
Greetings. :lol:
