Y-Axis is moving while printing
Lonzo
Post by Lonzo » Sun Jul 28, 2019 4:00 pm
I own a Geeetech Prusa I3X
I tested all the things in the manual.
Installing Repetier-Host (V1.6.0)
Installing the Drivers and finding the Printer in Repetier-Host, OK
Using Slic3r (V1.2.9) per Call from Repetier-Host, OK
Manually moving on the x,Y and Z axis, OK
Heating the bed and Extruder, OK
I worked my way through all the configurations.
So far, so good.
Loading File, slicing and starting to print, all works fine.
But all printing attempts gone wrong, because while printing the Y-axis seem to move!?
The printed lines wander in direction of the front of the printer more and more.
The grip of the filament on the surface of the glasplate is perfect.
I tried the newest version of Slic3r, the effect stayes the same.
I cant find a mechanical reason for this. Or can this happen, if the Y-Stepmotor is defect?
Additionally the printed lines are not straigt, they look more like a corkscrewer...
I reduced the printing speed to 30mm/s without effect, except longer printtimes ;)
Is there a configuration to fix this too?
I dont know, how to fix this. Can somebody help me, please?
Re: Y-Axis is moving while printing
Post by _kaktus_ » Sun Jul 28, 2019 4:44 pm
Hello.
Your printer is new. And you've probably just started your adventure.
So it's only natural that you need to gain experience and knowledge. For example, reading this forum. :roll:
The problem you're facing is layers shifting.
Almost everyone has to deal with it.
Look for topics in the forums that contain this problem. There are many of them. :D
Post by William » Mon Jul 29, 2019 9:29 am
So far, so good.
Hi, You may need to adjust the belt tension on the y-axis;
The drive board voltage can then be adjusted (0.8-1.2V).
jacoboram550
Post by jacoboram550 » Mon Oct 05, 2020 1:25 pm
This product is very nice and amazing and many users are satisfied with its features. I have bought this one, and I am satisfied with its services. I will recommend it to all of you because I hope, you will enjoy it. Coursework writing service.
Homer254
Post by Homer254 » Thu Sep 02, 2021 1:37 pm
Your stepper motors do not give positional feedback to your printer. So, if you forcefully move your motor during print, then the printer will not notice, and simply pretend it never happened.
McDVOICE
ducklife
Post by ducklife » Tue May 17, 2022 4:47 pm
I appreciate your sharing. The essay writing service is very cheap so every student love to get the Essay Writing service you share.
fall guys
eliebrooky
Post by eliebrooky » Tue Jul 05, 2022 4:27 am
Installing Repetier-Host V1.6.0.
So far, so good.
