Delta G2s
deepskysteve
Delta G2s
Post by deepskysteve » Fri Apr 27, 2018 9:09 pm
Hi All can someone explain what needs to be done know I have built the Delta printer when I home it just hits the end stops and keeps clickingboth with repetier host or from the LCD but I don't know what the next stage is to get the printer working any help would be appreciated.
Steve
Gingko
Re: Delta G2s
Post by Gingko » Sat Apr 28, 2018 3:37 pm
maybe you can try to check the endstops.
this post can be referenced:
viewtopic.php?f=13&t=17042
Barry7777
Re: Delta G2s
Post by Barry7777 » Sun Jun 24, 2018 6:22 am
I had experienced the same issue. After checking the endstops and wirings that were ok, I changed the stepper driver (polulu) of the axis and it solved the issue. I think the driver was dead.
Anyway, and it's not very well explained in the instructions, you must set the voltage of each stepper driver. They are not setup in the factory !
À Google search will give you a lot of help for a right setup.
