Cura profile for geeetech prusa i3 pro w
Share your configuration profile, please specify your printer model and the slicer software.
Paolor91
Post by Paolor91 » Thu Apr 23, 2020 3:53 pm
I have a printer geeetech prusa i3 pro w I would like to import it in Cura software but I can't get the profile, could you give me some directions ? thank you very much.
Re: Cura profile for geeetech prusa i3 pro w
Post by William » Thu Apr 23, 2020 4:59 pm
Hi, you can download this configuration file.
Geeetech-I3ProW.rar
(399 Bytes) Downloaded 1316 times
didibxl
Post by didibxl » Wed Jun 10, 2020 12:47 am
Hi ! I've downloaded in Cura 4.6.1. and that's not working on my Geeetech Prusa I3 Pro W, the printer is with 1 extruder and no G-Code to begin and ending the print.
Post by William » Wed Jun 10, 2020 9:09 am
Hi,this is Cura's configuration file, about some parameter settings
laumonto
Post by laumonto » Sat Nov 14, 2020 10:37 pm
I have tried to import the cure profile but I get a warning saying that the file does not contain any valid profile. I have tried to import it from settings-> printer-> manage printers -> profiles-> import. Any ideas on how I can configure the cure profile for Geeetech prusa i3 pro w printer?
Jackatack4455
Post by Jackatack4455 » Sun Dec 13, 2020 3:14 am
I have a GeeeTech i3 pro w and I downloaded the "resources" file and tried to apply it to cura 4.8 but nothing happened and it said "Cannot load (Definitions) file please try again later." I need a step by step explanation and some help because I currently cannot print without these files.
Carlson2852
Post by Carlson2852 » Wed Feb 24, 2021 5:25 pm
These are the only parameters I had to change (apart from choosing Prusa i3 as a machine on the James Armstrong's profile photo So some of these values are in direct conflict with what is listed in the Cura document that came with the I3. navyarmyccu
