LCD Screen on Geeetech A30 Not working after firmware update
Gymnast544
Post by Gymnast544 » Fri Dec 28, 2018 3:18 am
Just recently my A30 came in, and it was working OK (Autoleveling sensor wasn't working in firmware, but could print.). I pressed the button in the Easyprint3D software to Update the firmware, and the mainboard updated, but the LCD screen update failed, so now the LCD isn't working, meaning I can't level the bed and print. Through the Easyprint3D software I can't control the 3D printer right now, though mainboard updates are successful. I have tried a couple different ways to get it to work including:
Using the Smartto in order to put it on the Printer (Found the latest firmware on the page [1.35.56]) - LCD Timed out
There was a post on this forum about updating the LCD UI files through the SD Card, which I did (This one: https://www.geeetech.com/forum/viewtopi ... 65&t=60740)
I tried using the firmware toolkit (Here https://www.geeetech.com/forum/viewtopic.php?t=60814) but for the LCD it said uploading and then never had any status (Never posted a single percent)
And Easyprint 3d updater which didn't work as the mainboard it said worked but not the LCD. (Also worth noting, after trying updating Easyprint3d in the firmware updater still has an old firmware which didn't update listed for the current)
Right now I just need to get this printer working, as I am on a robotics team which needs certain parts printed out in the next 24 hrs.
EDIT: Just checked, Easyprint3D reads the current as 1.00.56 meaning that it thinks that the mainboard is fully updated but the LCD is on version 0
Thank you
Re: LCD Screen on Geeetech A30 Not working after firmware update
Post by _kaktus_ » Fri Dec 28, 2018 4:50 am
:mrgreen:
Try to do everything from scratch according to this description:
http://www.geeetech.com/forum/viewtopic ... 222#p82222
Gymnast544
Post by Gymnast544 » Fri Dec 28, 2018 11:14 am
I have tried doing exactly what is on that page, and it didn't work, as the mainboard would work but the LCD would time out.
Thank you though.
Post by _kaktus_ » Fri Dec 28, 2018 4:29 pm
Hi.
:mrgreen:
The firmware there is in a different version than you wrote.
Have you tried this version?
Gingko
Post by Gingko » Fri Dec 28, 2018 6:23 pm
When upgrading with Smartto firmware tool, are you insert the SD(TF) card that on the right side of the 3-in-1 box?
p_rhodan
Post by p_rhodan » Fri Dec 28, 2018 7:49 pm
Could it be that you have the same issue as I?
The micro SD card reader on the back of the LCD screen is damaged. Cards would only be read if I Push with my finger on the reader.
Gymnast544
Post by Gymnast544 » Sat Dec 29, 2018 3:12 am
After a couple of hours working with Geeetech customer service, we got the issue resolved, as I needed to use a different firmware than what I was trying to flash the printer with. Thank you all for your suggestions though.
liegesurfer
Post by liegesurfer » Mon Dec 16, 2019 6:04 pm
Hallo
I have still the Same Problem.
Can you exactly Name which Firmware ist working?
I run in the Same Trap during Firmware-Update with the easy 3 d Software.
Thank you
vert
Post by vert » Tue Dec 17, 2019 12:43 pm
i had to update my lcd firmware manually when i did this on my a30.
had to remove the sdcard from the lcd inside the case replace its firmware also.
