Home position on the A30, off to front left
SirSunshine
Post by SirSunshine » Sun Sep 02, 2018 7:08 am
Love my A30 but I noticed that the Home coordinates of the A30 are actually off the plate. They land on the front left of the plate by about 5mm on the x and y axis. This results in prints not being centered. Suspecting this may be an issue when I print really large items. I've already had to adjust printer start profiles for starting blobs which were off the plate.
I tried adjusting with an M206 Home Offsets command but still no change. I'm assuming that gcode is not supported. (http://marlinfw.org/docs/gcode/M206.html)
Anyone know if this is normal?
Thanks,
Chuck
hybridsix
Re: Home position on the A30, off to front left
Post by hybridsix » Tue Sep 04, 2018 12:22 pm
Chuck,
I actually adjusted the "print area" in the smartto motor tool to be 330mm x 350mm. This actually takes the print head to the travel extents. Then in software, you can set up the printer with a pad, or dump area of 10x20mm. This seemed to work great for me with repetier.
Gingko
Post by Gingko » Tue Sep 04, 2018 4:22 pm
Try to set up "Bed left" and "Bed front" value (in repetier host) as 5 mm for example, then load the model, center it.
SirSunshine
Post by SirSunshine » Tue Sep 18, 2018 9:17 am
Thanks for the suggestions. I'm OK with this for now but if I push something really large out, I'm going to need to compensate. If might be set off the plate to accommodate the weird Z homing function that bounces to find 0 when you hit up. If that was on the bed, it would be an issue.
c3poSAW
Post by c3poSAW » Fri Dec 28, 2018 6:20 am
Have the same Issue.
X0 Y0 is in Realty X-8 Y-20. This also effects Manual Leveling Tool. may there is a possibilty to set a offset for that like for Z?
otherwise some Mecanical adjustments are requiered
