A30 automatically pausing
maertaus
Re: A30 automatically pausing
Post by maertaus » Fri Feb 22, 2019 2:40 am
Mine keeps pausing with the original SD card that was supplied with the printer. I have done no firmware updates and slice with Cura 3.6.0.
Seriogal
Post by Seriogal » Sat Mar 09, 2019 7:53 pm
Same there. Printer is 3 weeks old. Latest Firmware from official site uploaded - v1.38.59 (it was nightmare to get it working :)...). A30 Hardware version 3.40. Slicer - Cura 3.6. Tested probable 10 different SD cards (all works perfectly with mine PrintrBot). Same result - random pause on all prints longer than 3 hours. I'm printing with ABS - "resume" is not an option with this material. I switched off filament run out sensor. This not helped. Any ideas what to try?
P.S. U use "Marlin" style G-Code in Cura. Maybe this is reason? Which style Geeetech suggests to use?
Seriogal
Post by Seriogal » Sat Mar 09, 2019 8:12 pm
update... With v1.38.59 it pause almost every print now...
Post by William » Tue Mar 12, 2019 11:28 am
You should check the gcode of it at first.
Maybe there are some gcode this printer not support.
Seriogal
Post by Seriogal » Fri Mar 15, 2019 1:22 am
Is there any list of supported and not supported G-Codes by A30?
Post by William » Fri Mar 15, 2019 5:11 pm
Pls check it
viewtopic.php?f=92&t=61924
robek25
Post by robek25 » Sat Jan 18, 2020 5:57 am
hi all i have the same problem i uploaded the latest software
on each print pause,
I tested the same g codes on tronxy x6a and it works fine.
i use cura and prusa slicer edition in all the same.
my geeetech a30 is the 24v version motherboard gtm 32
please help
the printer has 3 months
Post by William » Sat Jan 18, 2020 9:25 am
robek25
Post by robek25 » Sat Jan 18, 2020 10:38 pm
thanks
if anyone can give a specific answer to this problem, I am not told anything by the G-codes.
19.01.2020
00:04
today it was displayed on LCD during printing
pause and then temp_exception
